It is currently Wed Jul 23, 2025 8:56 am
PostPosted: Tue Oct 16, 2012 5:02 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
On occasion, I have had tearout occur when trimming the top and backs (flush bit). I just ordered a spiral downcut bit from Whiteside. But, I saw a comment recently about using climb cutting to avoid this. Do any of you do that?
PostPosted: Tue Oct 16, 2012 5:42 pm
First name: Trevor
Last Name: Gore
City: Sydney
All the time.
You can climb all the way round, but you need to make sure you're holding on to the guitar (talking table mounted router here); or just rout from the wide parts to the narrow parts, which gives you a climb cut where you need it. If you have big overhangs, don't try to take it all off in one hit, of course.
I always climb all the way round when cutting binding or purfling channels (using either a "vertical axis" machine or a hand held laminate trimmer).
All the bits I use for these types of cuts are "spiral" to some degree, either up or down. Gives a much smoother cut. Spiral down for purflings gives a very clean cut.
http://www.goreguitars.com.au
Users browsing this forum: Chris Ensor and 23 guests
