It is currently Wed Jun 10, 2026 8:50 am
PostPosted: Wed Oct 10, 2012 10:48 pm
Any body know if Zpoxy and seagraves vinyl sealer are compatible?
I'm concerned about adhesion.
PostPosted: Thu Oct 11, 2012 5:46 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I assume you are going to be doing the pore fill prior to the sealer. If that is the case there should be no adhesion problems as long as the surface is left rough enough for the sealer to grab on to. I would not sand any finer than 180grit before applying the sealer. If you do a z-poxy wash after the pore fill as a lot do these days the z-poxy would act as a sealer itself and the vinyl would most likely not really be necessary as long as the surface is not to smooth for the lacquer to grab on to.
Brian
