It is currently Fri Jul 25, 2025 3:21 am
PostPosted: Tue Oct 09, 2012 5:33 pm
First name: EddieLee
Last Name: Brown
I am installing Gotoh open back tuners part number GNS1B from LMI on my first guitar. I have not been able to find any instructions on installing these. I am confused about what size hole to drill for the shaft and how to counter bore for the bushing.
The shaft is 1/4 inch (6.35 mm) but by the housing where the shaft sets, the diameter is .295 inches (7.5 mm). Should I drill the through hole 0.295 inches or will 1/4 through hole be best to use.
What is the best way to put in the counter sink for the bushing?
EddieLee
_____________
EddieLee
PostPosted: Tue Oct 09, 2012 6:02 pm
Eddie,
That little lip is only 2mm tall, so I just use a countersink. Keep the rest of the hole at 1/4". You want a good fit for the shaft.
PostPosted: Tue Oct 09, 2012 6:03 pm
Drill a 1/4 inch hole all the way thru .. then drill for the countersink on the back end/plate of the tuner. You will need a Stwe mac drill/reamer for the bushing - I think the std size for waverlies works fine .. but measure the bushings to be sure
PostPosted: Tue Oct 09, 2012 8:03 pm
City: chicagoland
State: illinois
just experiment with different bits on a piece of scrap made of the same wood and find what works best
PostPosted: Wed Oct 10, 2012 2:18 am
+1
Ken Franklin
clumsy yet persistent
