It is currently Sun Aug 10, 2025 6:25 am
PostPosted: Sat Sep 15, 2012 10:45 am
Last Name: Flindall
City: Peterborough
Hi everyone,
I'm looking for some input on a problem I'm facing with my bending process. I've scoured through the forum looking for a reason to my problem, how to prevent it from happening again and how to fix it.
I'm using a Fox Bender to bend my sides with the following sandwich : slat/blanket/slat/kraft paper/wood/kraft paper/slat. The slats I've made from galvanized duct work and seem to work great. I'm also using reverse osmosis water. I wet the paper and then squeegee the paper off on the side of my bench. I lightly mist the wood as well and then squeegee the wood off as well.
But I keep getting staining on the inside of the sides, and the outsides look great! I've bent two different woods now, wenge and bubinga and got staining on both. It was workable with the wenge because the wood was already dark. I bent the bubinga last night and this is the result :
Image Image
I start my bends once I see steam and the sides bend like butter. This is usually around 220. I'm not waiting for the blanket to come up to the large temperature numbers I see everyone else using but the bending seems to go fine. With the wenge, I only heated once, then allowed to cool and I got staining. With the bubinga, I heated the side, allowed it to cool and then reheated the side with the same staining. Is it an issue of the inside of the bend not coming up to temperature like the outside where the blanket is?
And now the next question - apart from sanding, is there a way of removing this staining? I'm glad the outside looks perfect, but I want to clean up the inside of the rims as well.
Thank in advance guys, I really appreciate any input on fixing this problem.
Rob
Rob Flindall
Flindall Guitars
http://www.flindallguitars.com
https://www.facebook.com/FlindallGuitars
PostPosted: Sat Sep 15, 2012 10:57 am
Last Name: Flindall
City: Peterborough
Thanks Todd - I'll definitely try the foil. I have a zebrawood set and sapele set still to bend. Keeping my fingers crossed.
Now in your experience, will this sand out, or does this sort of staining go pretty deep into the wood?
Rob
Rob Flindall
Flindall Guitars
PostPosted: Sat Sep 15, 2012 4:08 pm
First name: David
Last Name: Eddy
City: Mandeville
State: La
Zip/Postal Code: 70448
Are you using distilled water? Any mineral in the water will cause staining!
PostPosted: Sat Sep 15, 2012 7:26 pm
Last Name: Flindall
City: Peterborough
I went to Culligans to pick up some distilled water but they no longer sell it as they now have reverse osmosis treated water. The lady there said it's 99.99% pure water. So there shouldn't be any minerals in the water.
I'll definitely try the oxalic acid - I just need to find a source for it here in Canada. Home Depot didn't sell it, but I understand that some pharmacy's may carry it.
Rob Flindall
Flindall Guitars
PostPosted: Sat Sep 15, 2012 8:38 pm
Last Name: Hosmer
Home Depot didn't have the oxalic acid?
Do you have a "paint store" nearby? Sherwin williams, Benjamin Moore, Porter, etc.?
A very common use for oxalic acid is cleaning of decks and driveways before sealing.
Always have plenty of sandpaper; it's rough out there!
PostPosted: Sat Sep 15, 2012 8:47 pm
Last Name: Flindall
City: Peterborough
Well at 5 minutes to closing time, the ladies in the paint department didn't seem too interested in figuring out if they carried the product. I did some research tonight and saw that deck cleaning was a common application. Thompson's deck cleaner wouldn't happen to be oxalic acid now would it? I'm going to go back to HD and have a good look around the deck cleaning dept and driveway sealing dept - thanks for the tip! We have a Sherwin Williams in town too, so I'll check there if the HD falls through. I'm really keeping my fingers crossed that the oxalic acid will clean up those stains. :)
Question though - once I find some oxalic acid, how do you apply it to the wood? Wipe on, wipe off? or do you let it sit for a bit?
Rob Flindall
Flindall Guitars
PostPosted: Sat Sep 15, 2012 9:09 pm
First name: David
Last Name: Eddy
City: Mandeville
State: La
This is just a crazy thought, but try oxyclean and then a little saw dust to pull up the oxyclean ! Sawdust really pulls stains out of concrete!
PostPosted: Mon Sep 17, 2012 12:39 pm
City: winnipeg
State: manitoba
Country: canada
Oxalic acid can be poisonous so it might be difficult to buy under that name. I have found that farm vet supplies carry various chemicals under their correct names.
Washing products that remove blood stains will probably comtain oxalic acid.
Reverse osmosis water is as good as distilled but dehumidifier water is probably as good for most shop uses.
Bob :ugeek:
PostPosted: Mon Sep 17, 2012 3:37 pm
First name: micah
Last Name: medlong
City: parma
State: ohio
Zip/Postal Code: 44129
I had a staining problem with bubinga and it sanded out just fine.
PostPosted: Mon Sep 17, 2012 5:31 pm
Last Name: Flindall
City: Peterborough
Thanks guys! Oxalic acid, apparently, is very difficult to find here in Canada. The only place I haven't gone yet is a local pharmacy to have the product ordered in. I did find a Behr deck wash, but I think the concentration is too low at 10% oxalic acid. I'll let everyone know how I make out. Thanks for the application info Todd.
Unkabob - I've been running a dehumidifier in my shop all summer and throwing the water out! I'll start bottling it now and calling it Luthier Magic Water. Lol.
Rob
Rob Flindall
Flindall Guitars
PostPosted: Mon Sep 17, 2012 5:48 pm
I've been wrapping my sides in paper, helps hold some moisture during bending and prevents staining at the same time.
PostPosted: Mon Sep 17, 2012 6:19 pm
First name: Trevor
Last Name: Gore
City: Sydney
Todd Stock wrote:
Mix the acid into a saturated solution and wipe on...once the stains disappear, wash and neutralize by wiping on a warm water and baking soda solution...try not to soak the wood, which can cause stuff to warp.
I wouldn't recommend neutralising with baking soda. Will turn some woods black (Aus. blackwood/black acacia particularly comes to mind). Best to keep the pH slightly acidic, so wash off with just water or dil. acetic acid (vinegar) if your water supply is alkaline e.g. limestone area.
http://www.goreguitars.com.au
PostPosted: Mon Sep 17, 2012 6:25 pm
First name: Ringo
Just sand a bit; it's likely just on the surface
PostPosted: Wed Sep 19, 2012 5:18 pm
Last Name: Flindall
City: Peterborough
WOWZA! :shock: I purchased a product from Home Depot called Behr Premium All-in-One Wood Cleaner that contains a less than 10% concentration of oxalic acid. I tried the product on my bubinga sides and voila! Here are the before and after pictures :
Image Image
I am duly impressed with the results! Not bad huh?
Rob
Rob Flindall
Flindall Guitars
PostPosted: Wed Sep 19, 2012 8:53 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Nice!!!!
Another source is a granular cleaning product called "Bartenders Friend" whose main ingredient is oxalic acid.
PostPosted: Thu Sep 20, 2012 11:42 pm
Last Name: Giltzow
City: Boise
State: Idaho
Zip/Postal Code: 83709
Hey Thanks for this thread. I took a Australian blackwood side out of my fox bender yesterday morning and had a large black stain on the inside at the waist. I did have it wrapped in kraft paper but still got the stain. I tried the Behr all in one wood cleaner with an old toothbrush and then used a mixture of warm water and white vinegar to clean it off. It worked great. Thanks again - Mike
guitarsbygiltzow.com
PostPosted: Fri Sep 21, 2012 7:26 pm
Last Name: Flindall
City: Peterborough
Nice! I'm glad it worked for you too Mike. I used very little of the Behr product - so a little goes a long way. Given the size of the jug, we probably have enough for, say, 500 guitars? Lol. Good luck on your build!
Rob
Rob Flindall
Flindall Guitars
Users browsing this forum: modkev and 20 guests
