It is currently Fri Aug 08, 2025 9:46 pm
 Post subject: potato chips
PostPosted: Thu May 24, 2012 9:03 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I have a set of cocobolo that has been in my workshop for 3 months or so now , one of the bookmatched backs will not lie flat , they have been stickered, the whole time, I have tried spraying water on the concave side , and even tried supersoft and weighted the backs down but the one back will not lay down??? any suggestions would be appreciated???!!!!
MK5acoustics.com
 Post subject: Re: potato chips
PostPosted: Thu May 24, 2012 9:38 pm
I had one like that once. I tried everything. Ironing will sometimes get flat, or using a heat blanket to flatten it. I finally gave up after none of that worked. I thinned it for building, glued it up and put it on a guitar. Worked fine. I have had no problems with it since I built it.
PostPosted: Fri May 25, 2012 10:58 am
If you have access to a dry mount press, used for dry mounting prints, that can work. Bigger the better.
PostPosted: Fri May 25, 2012 11:05 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
The fact that only one half is warped usually means that the wood had some casehardening before the board was resawn. In my experience, heating and pressing is the only way to permanently flatten it.
After the back is thinned to final thickness, slight warping can usually be handled with the back bracing. That assumes that the back can be thinned without flexing it so much that it cracks.
PostPosted: Sat May 26, 2012 5:51 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I`ve had this problem a few times.I layed the wood with the concave side down, meaning that the center of the piece was sticking up while the edges were touching on a concrete floor and then layed bricks on it.Took about 3 months to flatten out.Once flat I stickered it in my RH controlled room.Some of these have since become guitars with no problems.
James W Bolan
Nashville Tennessee
PostPosted: Sat May 26, 2012 6:56 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I have heated some in my kitchen oven and then placed them between two pieces of 3/4 plywood with some weight on top for a week and it worked.
Another day, another dollar.
