It is currently Wed Aug 20, 2025 4:49 am
 Post subject: truss rod rattle? Help!
PostPosted: Fri May 11, 2012 1:04 am
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
Doaah! i thought I'd solved most of my build problems but when I stringed up my latest, there is some kind of nasty buzz when I play the open D string. Must be a rattling truss rod! Has anyone ever solved this problem? I think I made a touch too much clearance when I installed my fretboard over the rod (or not). Hope I don't have to completely remove it now.
What usually causes this anyhow? Seems like I did everything as before with my other 8 guitars. Why now? gaah [uncle] [headinwall] :arrow:
PostPosted: Fri May 11, 2012 5:06 am
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
If it only buzzes on the open D, I would first check that the nut slot is OK. Fret the D at the first fret. If you don't get the buzz there then I would suspect the nut slot. I chased the same buzz all over the shop on #1 until I figured it out. If it turns out to be the TRod, the more experienced fellas here can tell you how to fix it. Pals, Vic.
PostPosted: Fri May 11, 2012 8:58 am
Last Name: Kincheloe
I once had a rattling D string, and it turned out to be the nut on its tuner was loose, allowing the washer to rattle.
PostPosted: Fri May 11, 2012 9:29 am
You can inject rubber cement too. I've done that twice. It works.
PostPosted: Fri May 11, 2012 11:03 am
also CHECK THE TUNER
that one drove me nuts a few times
PostPosted: Fri May 11, 2012 7:19 pm
First name: nick
City: Vallejo
State: ca
thanks for the responses. I'm pretty sure just by the sound of it that it wasn't a nut buzz, but I hope it is. Right now I have the strings off again and I'm doing a little fret levelling and bridge adjustment first. I removed the nut to see if anything obvious was underneath it. This is where patience and perseverance are golden.
I also tightened the machines a bit more. Does anyone have negative opinions of Ping tuners. I got them from Fat Dog at Subway guitars, who says they work fine. My budget's been very tight of late I'm afraid.
PostPosted: Tue May 22, 2012 11:42 pm
First name: nick
City: Vallejo
State: ca
Aha! Fixed! It was nothing thank god. I had broken the High E string and not replaced it. The empty tuner was simply rattling. oops_sign wow7-eyes :mrgreen:
I finished the guitar and it came out great. Maybe some pics soon.
PostPosted: Wed May 23, 2012 6:24 am
Well you sort of answered your own question about the Ping tuners ;)
It can happen to any tuner and it has happened to me too and it's enough to make you crazy especially when you'd swear that the sound was coming from the tail block and it's really a loose tuner. gaah
