It is currently Sat Jul 26, 2025 8:48 pm
 Post subject: Radius jig question
PostPosted: Wed Mar 28, 2012 11:08 am
First name: robin
Last Name: courtenay
City: andover
State: hants
Country: uk
I'm gonna be making a fingerboard radius jig from Todd Stock's plans and was wondering does it make any difference wether you slot the board before or after you radius it.Thanks all Rob.
 Post subject: Re: Radius jig question
PostPosted: Thu Mar 29, 2012 11:10 am
First name: robin
City: andover
State: hants
Country: uk
Thanks Todd,is there any particular reason you slot before radiusing?
PostPosted: Thu Mar 29, 2012 11:42 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
verhoevenc wrote:
Cause unless you have a radial arm saw its gunna. E pretty hard to slot after radiusing .P
Chris
Unless you have one of those StewMac or LMI setups where the blade cuts from the top - just like a RAS.
Kevin Looker
I'm not a luthier.
PostPosted: Fri Mar 30, 2012 12:41 am
First name: Harold
Last Name: Cagle
City: Portage
Zip/Postal Code: 49024
I always slot before radiusing, it just makes the flow of work constant for me
PostPosted: Fri Mar 30, 2012 7:16 am
First name: Jason
Last Name: McGowan
City: Corinth
Zip/Postal Code: 76210
Todd Stock wrote:
If slotting on a RAS, you have my deepest sympathy... ;)
Sorry to thread jack, but Todd, why your deepest sympathy? This is the route that seems like it would be the most accurate to me, but I'm still working on my first, so I am yet to see.
Jason McGowan
M&S Guitars
_____________________________
United States of America, looks like another silent night
As we're sung to sleep by philosophies that save the trees and kill the children....
Casting Crowns
PostPosted: Fri Mar 30, 2012 7:34 am
First name: Cecil
Last Name: Carroll
City: West Plains
State: Missouri
Zip/Postal Code: 65775
My RAS just isn't that accurate. There is enough slop in the mechanism to allow several thousands variation in slot location. It is a craftsman 2.5 HP saw with a very reasonable amount of use so it is not worn out, just sloppy.
cecil
PostPosted: Fri Mar 30, 2012 10:32 am
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
On the visit to the Woodshop Rocks shop, Duane was set up using a RAS for slotting. It was a dedicated set up and looked pretty nice and easy to use. He let his middle schoolers use it to slot. Just a nail in the fence and a Stew Mac template.
I have had the misfortune of being assigned to make some RAS work accurately in a sash shop, so I understand Todd's sympathy. Any dirt on the ways messes it up, those roller bearings and ways need to be spiffy clean, after that, there are just lots of parts that can add an inaccuracy.
Chris, I have been looking at RAS's for multiscale, if you have seen Sheldon Dingwal's set up, it is worth imitating, but it is on a sliding miter saw and the depth is set with a bearing, so you can slot after radius and have consistent slot depth. Very cool set up. Charles Fox has one in his shop, we just saw it set up with 5 blades for kerfing, he had a cool foot pedal to hold and index the linings.
They are big and finicky, hard to justify the space in the shop.
http://shastaguitar.com/
http://www.kalimbakit.com/
PostPosted: Fri Mar 30, 2012 11:17 am
First name: robin
City: andover
State: hants
Country: uk
Thanks for the replies , i'll be slotting by hand so i guess it will be safer to radius first.Rob.
