It is currently Thu Jul 31, 2025 1:48 pm
PostPosted: Wed Mar 28, 2012 5:12 pm
First name: Big
Last Name: Jim
Am going to apply a Black self stick PicGard to the top of the Purple Heart build . It has been buffed with buffing compound . Do I need to wipe it down with somthing to make sure it sticks properly ? And if so what is recommended to clean the top prior to sticking this on . idunno
Thanks .
 Post subject: Dumb Question # 426
PostPosted: Wed Mar 28, 2012 5:41 pm
First name: Tony
Last Name: C
City: Brooklyn
Naphtha removes wax so I would clean the area with some before trying to stick on the pg.
http://www.CostaGuitars.com
PMoMC
 Post subject: Re: Dumb Question # 426
PostPosted: Wed Mar 28, 2012 5:48 pm
First name: Big
Last Name: Jim
Was kinda what I was thinking , but this Laq is only a month cured and wasnt sure If i would be creating a finish problem for myself .
PostPosted: Wed Mar 28, 2012 5:58 pm
Last Name: Hill
City: Wesley Chapel
State: Fl.
Zip/Postal Code: 33543
Does naptha cause a problem with laquer?
Joe
My wife asks me "How many Guitars do you need?"
I reply "When I die count them; thats how many I needed".
PostPosted: Wed Mar 28, 2012 6:04 pm
First name: Big
Last Name: Jim
Wasnt sure thats why I asked , but guess not .
PostPosted: Thu Mar 29, 2012 8:17 am
City: Tyler
I've wiped nitro with naptha regularly with no problems. I use it during the buffing process to remove compound residue between compound grits.
PostPosted: Thu Mar 29, 2012 9:10 am
First name: Corky
Last Name: Long
City: Mount Kisco
I don't think you'll be creating a finish problem, per se, but I've found with the clear removable pickguards, that they do cause some surface finish anomolies when you leave them on for any period of time - especially if the finish is still gassing off. If you're putting that pickguard on for good - I wouldn't worry about it. If you anticipate removing it after time, I would expect there to be a visible difference on the finish of the top - from where the guard was and wasn't...
PostPosted: Thu Mar 29, 2012 10:00 am
First name: Big
Last Name: Jim
Thanks for the responses . Yeah I have seen where a picguard has been rremoved and there is a visable color diffrence in the nitro Laq. This one is going to be permenant so there shouldnt be any issue there . I was just curious mainly because the nitro is fairly fresh .
PostPosted: Thu Mar 29, 2012 11:44 am
First name: Patrick
Last Name: Hanna
State: Missouri
Related question, please. Corky's insight about off-gassing under a pickguard is a good one and I hadn't thought much about it until just now. How long do you think nitro finishes continue to off-gas? I realize this will depend on some variables such as thickness, etc. The only instrument I ever made with a stuck-on pickguard was cured a month before buffing, and it was probably another two weeks before the pickguard was mounted. I expect it was fully cured by then, but I'm curious.
Thanks.
Patrick
PostPosted: Thu Mar 29, 2012 12:00 pm
First name: Big
Last Name: Jim
Yeah , kinda the same line of thought here . Its about a month old as far as the Laq is concerned and I will have the picguard on in a week so ( 5 ) weeks from spray to stick on PG . Is that reasonably long enough ?
PostPosted: Mon Apr 09, 2012 11:50 am
First name: Big
Last Name: Jim
Bump.
PostPosted: Mon Apr 09, 2012 12:01 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
noooooo no no no, do not use Acetone on finish. If you do, you will be a shoe-in for "Doofus of the Month"
Acetone will eat through lacquer like a hot knife through butter.
edit* you may be able to use a general purpose adhesive remover. However, like with all things, test on a scrap piece first!
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Mon Apr 09, 2012 12:25 pm
Last Name: Hill
City: Wesley Chapel
State: Fl.
+1
Joe
PostPosted: Mon Apr 09, 2012 12:41 pm
First name: Big
Last Name: Jim
Thanks , I kinda thought that it was too harsh . Havent had much need in the past to use either one so its an area that I wasnt sure about .
Users browsing this forum: Bing [Bot], DanSavage and 19 guests
