It is currently Sun Aug 03, 2025 11:33 am
 Post subject: zpoxy for binding
PostPosted: Wed Mar 28, 2012 4:05 pm
First name: Sean
anyone ever use zpoxy for gluing koa wood binding? I'm thinking with it's long open time that it might be easy to use.
Sean
change isn't synonymous with improvement
instagram.com/bucketguitars/
 Post subject: Re: zpoxy for binding
PostPosted: Wed Mar 28, 2012 4:50 pm
I can't imagine why you would want to use epoxy to glue wood binding. Messy, requires mixing, and a fussy sort of joint. I'm a proponent of CA (strap in place, wick in glue), lots of others seem to like fish glue for high initial tack and long open time.
(I'm assuming you mean Z-poxy epoxy, not finishing resin).
PostPosted: Fri Mar 30, 2012 1:55 pm
It's hard to beat Titebond for gluing wood to wood. If you need a longer open time, Titebond 3 is good too.
PostPosted: Fri Mar 30, 2012 2:40 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Hot hide glue...Easy and really fast. And it's ridiculus how easy it is to clean.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Fri Mar 30, 2012 3:15 pm
Sean, another thing to remember is that the zpoxy typically referenced around here is a "finishing" epoxy, not really meant for glueing stuff together.
(...sorry Matt...missed your last line)
Milton, ON
PostPosted: Fri Mar 30, 2012 10:19 pm
First name: Sean
thanks for all the replies. I ended up using titebond extend. I has a long open time. I did the top one night, and just finished the back. After taping, I then used the twilltape and wrapped it real tight. Everything went really well.
Sean
PostPosted: Fri Mar 30, 2012 10:53 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
May I ask a dumb question? Just why exactly is z-poxy finishing resin a poor glue?
PostPosted: Fri Mar 30, 2012 11:40 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I respect that view, but I'm not sure that's a definitive answer to my question. What is the difference between a finishing resin and an epoxy glue?
PostPosted: Sat Mar 31, 2012 12:58 am
Finishing resin does not have the strength of an epoxy designed to bond materials together. Another advantage with Titebond or LMI luthiers glue is that is softens with heat making it easy to close up any little gaps that you may have missed during the initial glue up.
Users browsing this forum: Michaeldc and 40 guests
