It is currently Thu Aug 07, 2025 7:22 am
PostPosted: Thu Mar 22, 2012 8:47 pm
Hey all, I'm starting a build that's a commission for a friend who's an upright bass player, but also plays guitar. It's a baritone six string, and I was considering using curly maple for the neck, since I have a ton, and I thought it might have a familiar feel to it. Any thoughts on advantages/disadvantages? My mentor, James Condino, is very much a fan of mahogany necks on guitars, though he plays a lot more upright and mando, which, of course have maple necks. Not sure what to make of that...
TIA
Ken
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Thu Mar 22, 2012 10:25 pm
Disadvantages? A bit heavier than mahogany.
Advantages? Stiffer, and in my opinion yielding better sustain and volume.
Also more beautiful, and--not to be discounted--you have a ton of it.
PostPosted: Thu Mar 22, 2012 10:33 pm
State: ON
Disadvantages - harder to carve than mahogany, but you have to weigh that against the other advantages Steve mentioned.
I'm hand carving a quilted maple neck right now and I don't plan to do that again for a long time. But it will sure look cool when it is done.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Thu Mar 22, 2012 10:34 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I think the curly maple will make a great neck, with good Mahogany getting harder to find and expensive I am sure we will see a lot more non Mahogany necks.
Fred Tellier
PostPosted: Thu Mar 22, 2012 11:20 pm
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
Less stability than mahogany.
But I wouldn't worry about it though If I had a good piece of straight grained, well aged maple.
I built an acoustic guitar with a rock maple necks that joined at the 12th fret. No problems.
PostPosted: Thu Mar 22, 2012 11:24 pm
First name: Nils
Last Name: Johnson
City: Boston
Actually - I would worry about it with a baritone guitar. A regular 6 string would be fine in my opinion. But with all the tension of a baritone, I think I'd want something slightly more stable.
PostPosted: Fri Mar 23, 2012 1:18 am
State: Serbia
concerning this post could somebody elaborate grain orientation in maple case because several time I read that maple is stronger when it's flat sawn
fric
PostPosted: Fri Mar 23, 2012 1:42 am
On a baritone a maple neck might feel a little unbalanced because of the longer scale length.
Ken Franklin
clumsy yet persistent
PostPosted: Fri Mar 23, 2012 10:18 am
I like both.But if you have more maple to work with, i don't think i'd go with mahogany unless that's what the client wants. I build more necks with maple as that's what i have a ton of and i like the look of curly maple much better. it is harder to carve, but it has an advantage of not needing porefilling. ;)
PostPosted: Fri Mar 23, 2012 10:43 am
Millions upon millions of maple neck guitars out there. More maple than mahogany, I'd wager.
PostPosted: Fri Mar 23, 2012 11:34 am
First name: Patrick
Last Name: Hanna
State: Missouri
I don't know about baritone guitars, but I'm thinking of the maple neck on my own archtop, as well as all the maple necks on 7-string jazz guitars, mandos, upright basses, banjos, and on and on. I wouldn't worry about stability and if you've got a ton of it then you're already familiar with cutting, shaving, sanding it, etc. I wouldn't hesitate to use it as long as the maple figure will pair well with your choice of body woods. Man...I wish I had a ton of it to work with.
Patrick
PostPosted: Fri Mar 23, 2012 3:43 pm
I'd say go for it ... and yes, flatsawn maple is about the same stiffness as quartered .. its just not as stable, ie it will move more with temp/rh changes.
PostPosted: Sat Mar 24, 2012 9:14 am
If the maple is well seasoned and hasn't shown any tendency to twist or move, it'll be a fine and stable neck. Flat sawn is great, too, and will show its best figure on the side of the neck instead of the back of it, so it'll be even prettier(if it has any figure, that is).
Millions of Telecasters and their countless clones can't all be wrong.....
Agree with using a good rasp for carving, as well as a scraper! A well sharpened scraper can make quick and effortless work of the final shaping.
PostPosted: Sat Mar 24, 2012 4:25 pm
Filippo Morelli wrote:
Maple is a wood. I see no reason not to use it if that's your desire.
Filippo
Thanks for clearing that up.
Here's a few of my stash:
PostPosted: Sat Mar 24, 2012 8:30 pm
Todd Stock wrote:
Siri makes an ash of us all from time to time...
Hey that's right...ash makes a good neck too.
PostPosted: Sat Mar 24, 2012 8:45 pm
Though usually just the users. I'm pretty sure I could take her in a cage match.
PostPosted: Sat Mar 24, 2012 11:16 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
They look very nice but are extremely top heavy on an acoustic. I own one and it's okay if you don't mind the headstock scrapping on the ground. Now that is an bit of exaggeration but not to much...Mike
Another day, another dollar.
Users browsing this forum: Ken Lewis and 44 guests
