It is currently Thu Jul 31, 2025 1:45 pm
 Post subject: Thoughts on a cedar neck
PostPosted: Sat Mar 24, 2012 12:29 pm
I'm working on two Cedar necks for my Walnut build, one Port Orford and one Eastern red. I'm leaning towards using the Eastern red.
Any thoughts on using Eastern red for a neck.
Scott
PostPosted: Sat Mar 24, 2012 2:54 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Unless you have vy clear (no knots) stock, you will find it splintery/ brittle , but easy to carve.Might want to reinforce it with cf in center for classical.Have not used port o cedar, but some have used it for tops and will chime in.
PostPosted: Sat Mar 24, 2012 4:35 pm
First name: Stuart
Last Name: Gort
I just finished two necks of Port Orford Cedar...and two electric bodies. Although this was primarily a tone experiment I couldn't bring myself to make these necks soley from POC. My first impression, though grounded in....well...something less than experience, was that it was not quite stiff enough to use by itself. I laminated a healthy strip of Bloodwood and Wenge down the middle of them.
The luthier I bought this wood from makes Flamenco guitars with solid POC necks. He said he never had any problems.
StuMusic
PostPosted: Sat Mar 24, 2012 5:28 pm
PO cedar is incredibly strong, approaching Doug Fir in strength. I would not hesitate to use it for a neck if it is strength you are worried about.
L.
PostPosted: Sat Mar 24, 2012 6:15 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
ERC is not very stiff for its weight. I would definitely use some reinforcement.
POC is another world. It is a world-class tonewood, with very high stiffness to weight ratio. ERC is at the other extreme.
In fact, about the only similarities are that both woods smell and have 'cedar' in their name.
PostPosted: Mon Mar 26, 2012 5:37 am
Ken Parker makes me want to try all sorts of crazy building fu.
Users browsing this forum: DanSavage and 20 guests
cron
