It is currently Tue Jul 22, 2025 2:59 am
PostPosted: Tue Feb 14, 2012 12:09 am
Last Name: O'Melia
City: Huntsville
State: Alabama
http://www.luthiertool.com/slot%20head%20fixture.html
Ok, I'm a DIYer in so many ways, but I have found myself coming back to this time and again. Does anybody have good/bad thoughts in this? I've built my own slotting templates, but never happy with them.
PostPosted: Tue Feb 14, 2012 12:30 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Hi Mike,
I have the Luthier Tool slotting jigs. I love them! They are fully adjustable and turn out very accurate slots and tuner holes. Very repeatable and easy to use. Like all good tools though, they ain't cheap, but you do get what you pay for from Chris! HTH.
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Tue Feb 14, 2012 4:03 am
I have it, and I love it. I wish all my jigs were this nice...
PostPosted: Tue Feb 14, 2012 7:32 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks guys. Sounds good to me. I have to admit, that order page is confusing. All those additional parts for sale make it look like an incomplete kit. Did u find it to be a "complete" kit? Other than the 8 hole jig, Chris tells me that all that other stuff is replacement stuff.
Did any of you buy the templates and bits? Or did u find them elsewhere at better prices?
(are they standard stuff?)
PostPosted: Tue Feb 14, 2012 8:18 am
It is a fantastic set up. I got the combo kit, but so far I've only used the steel string squarish slots.
The brass template guides and router bits can be found elsewhere (Woodcraft, Rockler, Amazon, etc), those are standard parts as long as you have a fairly standard router/trimmer base. You just have to make sure you get a 1/4" spiral bit long enough to go full depth of the jig template plus the headstock thickness. I don't recall it being hard to find one that worked.
PostPosted: Tue Feb 14, 2012 9:22 am
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
That looks like a good set up, lots of pieces.
I made my own in a 2 stage fixture. 1 to drill the holes for a slothead and then the oversized router template platform that keys off the holes. Both templates are split and doweled together so they easily adjust to different sized pegheads. Works well, repeats, both sides come out the same, doesn't even need to be clamped for the routing stage as the compound angeling of the holes and peghead pull it all in tight.
Not sure if I was making a bunch of them if they would be any cheaper than what your link is showing though.
Tim
PostPosted: Tue Feb 14, 2012 10:42 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I actually want it and the butt wedge vise. I can't say for sure, but their template bushings seemed a bit high priced.
Anybody used the butt wedge vise? Can you cut the wedge with it? For straight edges, I realize that is no big deal, but for curvey shapes, that would be a nice feature.
PostPosted: Tue Feb 14, 2012 10:57 am
Their "accessory kit" is not really that bad ($60 for template guides and router bit), though for about that you could get a complete template guide set instead of just the sizes needed for the jig. Those template guide sets run about $35-40 and the spiral downcut bits run about $20-25 or so.
PostPosted: Tue Feb 14, 2012 12:15 pm
I have this jig and use it for both steel string and classical slot heads. I've used it with success many times.
Sometimes something looks expensive at first sight, but the more you use it you realise that it would be cheap at twice the price.
Buy it without hesitation, you'll never regret it.
Users browsing this forum: DennisK, Juergen and 34 guests
