It is currently Sun May 03, 2026 1:20 pm
PostPosted: Thu Feb 02, 2012 7:50 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Anybody have a good way to collect a good amount of ebony sawdust for filling with CA glue? I know I can just sand away by hand but thought someone would have a way to collect it with power tools.
Hutch
PostPosted: Thu Feb 02, 2012 8:22 pm
Sorry Chuck... I just clean it up off of the bandsaw table. Hand, onto paper, into jar. I don't use the bandsaw to make sawdust, just when I'm resawing or cutting exotics or other I collect it. Guess that makes me a hoarder!
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Thu Feb 02, 2012 8:35 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I save the dust when I sand the Bridge bottoms to match top radius, I have a whole pill bottle full, one bridge sanding gives quite a bit of dust.
Fred Tellier
PostPosted: Thu Feb 02, 2012 9:05 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
I have a big bag of the stuff. I just added a bunch by sanding radius to fretboards.
PostPosted: Thu Feb 02, 2012 9:54 pm
Last Name: Ulman
City: Bellevue
State: Washington
I made a pile of ebony end grain dust from a fingerboard cutoff using a small disk sander sitting on top of a large sheet of freezer paper to catch most of it.
Joe
PostPosted: Thu Feb 02, 2012 9:58 pm
First name: Rob
Last Name: Brown
City: Melbourne
State: vic
Zip/Postal Code: 3142
Hutch,
I had a retired Italian Cabinet maker [Tony] come in to my work shop a few years back , we were talking woodwork and he looked down at the walnut table we were working at ,filling a crack with walnut saw dust and glue.
He told me two things that amazed me , they were such good ideas . they are to do with hide glue .
No 1 should work with whatever glue used.
1. Was when he was a young apprentice he had the job of planing the end grain of a board ,to get the end grain shavings ,to make a filler mixed with glue. Being end grain it crumbles into the finest particles. And he could produce what was needed ,quickly, taking fine shavings.
2. Nothing to do with your question, but the next thing he told me was when mixing a wood /hide glue filler to fill a knot hole in a board that was going to be veneered over, he would mix charcoal in the mix as well,which would control the shrinkage problem with hide glue.
Rob.
PostPosted: Thu Feb 02, 2012 9:59 pm
Got most of mine from sanding fingerboard radius....brush onto a paper, then into 35mm film canisters (remember Kodachrome??). Have a dozen canisters with different species.
Milton, ON
PostPosted: Thu Feb 02, 2012 10:31 pm
First name: Chuck
City: Houston
Rob B, I love those stories of how the old Italians would work, particularly since I'm half Italian too. Thanks for sharing.
Joe, I like how you did that with the freezer paper. Did you still get alot of dust in the air?
PostPosted: Thu Feb 02, 2012 10:33 pm
First name: Chuck
City: Houston
Dave S, I never thought about saving the different species of dusts. Good idea.
PostPosted: Thu Feb 02, 2012 11:23 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I use a drum sander in the drill press when making ebony bridges. I just place a piece of cardboard on the table to catch the dust. I keep a few different kinds....ebony, rosewood, maple, holly, mahogany, and black locust.
I have found that I prefer black locust dust when repairing maple bridgeplates. It works equally well with CA or hot hide glue.
PostPosted: Fri Feb 03, 2012 1:20 am
Last Name: Ulman
City: Bellevue
State: Washington
Yeah, I guess it's pretty dusty. I do this sort of thing outside on a calm day and wear a mask.
Joe
PostPosted: Fri Feb 03, 2012 11:31 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Yo hutch I have different grades of ebony dust in spice bottles,I have thicker dust from bandsaw , finer dust from sanding machines and , uber thin scrapings from scraper plane, depending on what I am trying to accomplish.Viva la dolce vita.For filling in low spots I use thinnest dust mixed with super thin ca.To build up the cavity I come back agn with a thicker dust and med .gel ca to raise the cavity slightly higher than the fb and then level with file and 320
PostPosted: Fri Feb 03, 2012 11:41 am
City: chicagoland
State: illinois
i thought i was the only one who saved dust! ha
the charcoal idea is intriguing
PostPosted: Fri Feb 03, 2012 8:43 pm
I never liked using sawdust as a filler-I have always used powdered dyes.
When mixed with epoxy it basically dissolves so creates less "micro- pockets" (I just made that up) so it's thinner and can get into a much tighter space.
I have 30 different colors thanks to a Mohawk Finishing Products large touch up kit that I have had for forever.
I bought a large container of the black dye since that is the one I mostly use.
PostPosted: Sat Feb 04, 2012 3:04 am
I've been using various dusts for over 20 years; no issues. No chemicals, either.
I save 'em in watch maker's cases, available from Lee Valley:
http://www.leevalley.com/en/wood/page.a ... 4948&cat=1
I can clearly see what is in each one. As a filler, it's best to choose a wood, even if it's not the same one you're filling, that is one or two shades lighter, because the glue will darken it. When we look at old inlays, we often see that the old filler is darker than the surrounding wood. That lead me to believe that the filler, despite most likely being the same wood, once saturated with glue, doesn't fade like the surrounding wood, but remains darker. For at least ten years now, I've chosen lighter woods that darkened enough to blend nicely(for example, walnut with EIR), and have watched them "age" nicely.
When I need to refill a case, I head to the thickness sander, place paper on the conveyor, and make sure I don't turn on the dust collection. Running a short piece through a time or two fills a watch case.
I also have collect coarser shavings at the band saw, as others have noted, but haven't found a good use for them yet, other than the smoker.....
PostPosted: Sat Feb 04, 2012 7:19 pm
Me too - usually from the oscillating sander or the spindle sander. I just put it into ziploc baggies. Got 4 or 5 of em I keep around for whatever.
PostPosted: Sat Feb 04, 2012 7:33 pm
I like to use a file or a fine rasp to make dust for filling inlays. For one thing, it seem "cleaner" than what is produced by abrasive paper, and I find the coarser the dust, the closer its color will be to the surrounding wood. Of course, these days, with cnc'd inlays, there isn't much need for fillers... ;)
PostPosted: Sat Feb 04, 2012 7:36 pm
For filling small gaps and divots I use lacquer for the binder instead of glue. This helps to keep the sawdust the same shade as the piece of wood it came from.
PostPosted: Sat Feb 04, 2012 10:37 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
I use dust from my power sanders for most woods, but for spruce, the only method that has worked for me is a file on end grain. Abrasives always leave abrasive particles in the dust that are much darker than the spruce. I use the file on Western Red Cedar too, and I usually add a little spruce dust to get a lighter shade that will be a match when darkened by glue.
PostPosted: Mon Feb 06, 2012 6:54 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
I save ebony dust and corian dust for filling too deep nut slots in the little bowl shaped plastic ketchup take out containers and lids from fast food places.
Users browsing this forum: Glen H and 199 guests
