It is currently Fri May 01, 2026 11:17 pm
 Post subject: cold weather checking
PostPosted: Thu Feb 02, 2012 5:42 pm
will varnish check the same as laquer when warmed to quickly from the cold?
PostPosted: Fri Feb 03, 2012 12:58 pm
just a simple yes or no, anybody?
PostPosted: Fri Feb 03, 2012 2:39 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
If by varnish you mean polyurethane, then no. Poly is fairly flexible. I'm not too sure about water based poly, though.
Alex
PostPosted: Fri Feb 03, 2012 3:42 pm
The problem is that there are too many variables to answer the question as posed. 'Varnish' is a whole family of things; reactive finishes, usually based on an oil and a resin, that harden by polymerization in the presence of air (traditional varnishes) or water vapor (polyurethane). 'Spar' varnishes, that have a high proportion of oil in them, are very flexible and unlikely to crack, while 'rubbing' varnishes tend to be more brittle. Much will also depend on how the finish is applied, how thick it is, and whether there is some sort of undercoat or sealer present, and what that is. Given enough provocation, even the wise will crack....
sorry....
PostPosted: Sat Feb 04, 2012 1:25 am
thank you
PostPosted: Sat Feb 04, 2012 6:34 am
As an example, my first classical about 50 years ago was a Hagstrom Espana. Driving to a lesson in MInnesota with the heater barey working, the guitar got very cold. Upon arriving at the lesson, I opened the case and the finished crackled as I watched.
