It is currently Sun May 03, 2026 10:23 am
 Post subject: Dyed Epoxy
PostPosted: Fri Jan 13, 2012 11:56 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I want to fill a laser engraving with dyed epoxy, black or rust colored. Need resin brand and dye brand suggestions please. Thanks!
 Post subject: Re: Dyed Epoxy
PostPosted: Sat Jan 14, 2012 12:35 am
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
West System. I use tempera when it's not structural.
But don't over do it.
PostPosted: Sat Jan 14, 2012 12:49 am
First name: David
Last Name: Morris
City: McKinney
West Systems also manufactures a black mix-in dye that's not too expensive. It's to lower friction on boats, but hey, why not?
David Morris
PostPosted: Sat Jan 14, 2012 1:07 am
I would suggest pigment rather than dye.I have used the one designed to colour concrete.
PostPosted: Sat Jan 14, 2012 1:51 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I'm actually looking for a recipe. Actual resin name plus actual dye/pigment name.
I think I'm close based on what I've seen here
PostPosted: Sat Jan 14, 2012 3:06 am
First name: Chuk
Last Name: Tang
Country: JAPAN
Have a look at the System Three products too. They sell a whole load of epoxies and hardeners. They also have a tinting epoxy paste. I personally have used their GelMagic product as an adhesive, but it could be used to fill engravings too. I also dyed it black with their paste and it is basically pure black now. After its cured, its really hard too. Not sure if that is a good thing for you since it will crack if you flex it too much. T88 is a bit more flexible. I'm not sure you would need a structural epoxy though for engravings. Just get any quality epoxy and add some lamp black or something to it. It should go black with only a small amount.
PostPosted: Sat Jan 14, 2012 3:12 am
Have you considered the engraving filler that Stew Mac sells? It's made by Grit Laskin.
PostPosted: Sat Jan 14, 2012 8:20 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I asked Petros about this at Woodstock this year, he uses epoxy with black tempera for his purflex. Did not say which epoxy though I'm sure he would answer a direct question via e-mail. I like Sytem 3's SB112 myself for it's clarity.
Brian
PostPosted: Sat Jan 14, 2012 11:03 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Mike, my typical approach is to mix Mohawk black powder stain with epoxy. A little of that powder can make epoxy coal black. I use it all the time with inlays.
Ken
http://www.casperguitar.com
PostPosted: Sun Jan 15, 2012 9:00 am
First name: Bryan
Last Name: Lafleur
City: Athens
State: Tx
Zip/Postal Code: 75752
I've had good luck with Transtint black with System 3 epoxy. But a word of caution, don't use metallic powders with it, ones I've tried turned green. Rep at the company said it was because of caustic ingredients in the epoxy.
Bryan Lafleur
www.lansegriseaccordions.com
PostPosted: Mon Jan 16, 2012 2:27 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Stew mac sells pigments for coloring epoxy for inlaying....Mike
http://www.stewmac.com/shop/Inlay,_pear ... 3&xsr=3484
Another day, another dollar.
PostPosted: Mon Jan 16, 2012 11:21 am
First name: Ron
Last Name: Belanger
Mohawk also makes an excellent line of colored pigments. I have used the black and brown for inlay. Heard about it from Dave Nichol at an ASIA inlay seminar.
PostPosted: Tue Jan 17, 2012 11:52 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks all, I'm going with the furniture powders & epoxy.
PostPosted: Wed Jan 18, 2012 8:51 am
Last Name: Cox
Product wise - the jar of pre-mixed black pigment I have says "System 3 Epoxy Pigment, Black".. Works real good in epoxy.. Takes one little blob on the end of a toothpick to dye about 1-oz of epoxy pitch black.
If you want something cheap that's super, perfect pitch black - it's hard to beat Lamp black... Available in most craft stores.... It's a fancy name for carbon black.... You could also make some yourself with a piece of lump charcoal and a mortar and pestle...
Just watch out - it's a powder and it gets all over everything! Literally... You won't know it's on your hands till you pick up something and leave black fingerprints....
Anyway, the upside is that it takes very little to perfectly dye stuff black... and it works with most anything... You can mix it into white glue or superglue if you are so inclined...
And.. It's more or less chemically stable - so it won't cause weird problems... Very likely the "Epoxy pigment, Black" is just mineral oil mixed with lamp black (THat's how we dyed all flavors of plastics black)... but it doesn't say... so I don't officially know...
PostPosted: Wed Jan 18, 2012 9:26 am
Last Name: coloccia
Country: States
I use transtint in epoxy too for other colors, though you won't really get an opaque color. Why not just buy black epoxy?
PostPosted: Wed Jan 18, 2012 3:03 pm
Last Name: Shannon
City: Milford
State: OH
I've used SM's black epoxy for ebony headplate and fretboard inlays and it's worked great for me. Undetectable under finish in my experience.
PostPosted: Sun Feb 05, 2012 10:20 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I bought several of the furniture powders (Behlen) and they worked awesome with epoxy and CA! Inlay gaps were flawlessly filled with CA and black powder. The stuff is really black, no graying with CA. Logo inlay with black powder and epoxy was perfect.
Thanks!
PostPosted: Sun Feb 05, 2012 11:35 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I use this epoxy that I get from a local chemical supply store. I don't know who made it but it sure smells like system three... it's a 3:1 mix.
Typhoon Guitars
