It is currently Mon Aug 04, 2025 3:30 pm
 Post subject: Super thin Rosette
PostPosted: Fri Dec 16, 2011 7:14 pm
I’m trying to make a Rosette for my next build, this one wound up pretty thin, around .042
It’s not inlaid yet, do you think its okay to use, I don’t think I’ll sand through it when finishing.
I’m worried about it warping, shrinking or maybe cracking later on.
Any thoughts,
SA
 Post subject: Re: Super thin Rosette
PostPosted: Fri Dec 16, 2011 7:25 pm
First name: Jim
Last Name: Hansen
What is it made of?
You could laminate another veneer to the back of it if you are worried about it shrinking or cracking under the finish.
Jim Hansen
PostPosted: Fri Dec 16, 2011 7:30 pm
Sorry...brain fart. laminate the back, that's the answer.
It's Sycamore and Walnut
Thanks for the wake up Jim
PostPosted: Fri Dec 16, 2011 8:42 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
A .022 backer veneer (cedar , spruce) glued to your rosette would give you abt .065 just the right thicknesss IMHO for an inlaid rosette, or leave as is
PostPosted: Fri Dec 16, 2011 9:24 pm
if you're careful about for deep you route your channel for the rosette, theres no reason 42 isn't thick enough. Go a scoch (as Robbie would say) deeper on the route then bring the top down to the rosettes level. All a veneer is doing is adjusting how deep you route.
PostPosted: Sat Dec 17, 2011 10:07 am
I agree with Zach. Many of the premade classical rosettes are around 1mm thick, which is .039". you just have to be very careful when leveling the rosettte, and or thicknessing the top
Matt Jacobs
"Don't tase me bro"
PostPosted: Mon Dec 19, 2011 3:19 pm
First name: Adam
State: Oklahoma
+1 for Zach's answer. I think Cumpiano's book recommends around 0.040" thick rosette pieces. I think.
Adam
