It is currently Tue Aug 12, 2025 5:06 am
PostPosted: Tue Nov 29, 2011 9:28 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I/ve cut up 8 pcs of anigre 1in by 36in long by 5.5mm thick veneer to glue to a 3 ply veneer of 1.8mm B/W/M. I have abt 8 different glues on hand . Will bend this at 250 deg f on an alum overholtzer CL jig. I have the following glues, which would be the most heat resistant ?? hide glue 192 test , white PVA, titebond original, CA, system 3 epoxy #2 30 min time, gorilla white, very short open time 5 min , elmers glue all . titebond new translucent glue ??
PostPosted: Tue Nov 29, 2011 4:53 pm
Well, I only use TB origianl for gluing up binding ... works just fine for me. I bend everything hot and fairly quick in the fox .. maybe 300-320 ...
PostPosted: Tue Nov 29, 2011 7:37 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
+1 on TB original. Tape mine together a few places,in pairs. Wrap in tin foil and bend on the hot pipe when I do the sides.
Brian
