It is currently Mon Aug 25, 2025 1:32 pm
PostPosted: Fri Nov 04, 2011 7:46 pm
State: PA
After finishing (FP), my end grafts are perfectly smooth to the touch & to the eye. But after 6 months or so, I can clearly feel the joints. My woods are well seasoned & acclimated to my shop. What am I doing wrong?
PostPosted: Fri Nov 04, 2011 7:53 pm
Nothing, that's totally normal wood behavior.
Different woods will react differently to changes in humidity, thus the feel of the joint when you pass your finger on it. Having wood that is 'acclimated' doesn't mean it's dead matter; it will still move depending on the relative humidity around it.
Alain Moisan
(Now building just for fun!)
PostPosted: Fri Nov 04, 2011 8:06 pm
Last Name: Kincheloe
6 months? Mine show after a week or two.
I like it.
If everything is too flat and shiny, it reminds me of those painted on rosettes on cheap classical guitars. I was pleasantly surprised with an inlay recently, which I used multiple pieces of ebony on, even though it's pretty much pitch black and the pieces touching together could have been done in one large piece. But after the shellac had time to dry, you can see the seams between pieces, and a bit of the grain showing the orientation of each piece. It looks "real" :) (because it is)
PostPosted: Sat Nov 05, 2011 1:35 am
First name: Dominic
Last Name: Regan
City: Canberra
Its a good idea to let the glue fully dry and for all the additional water introduced into the joint to leave the wood before you start sanding or scraping the end graft flush. If you sand too early and level it, the wood will keep drying and shrinking and leave lines or cracks through the finish at the joins.
Dom
PostPosted: Sat Nov 05, 2011 8:49 am
First name: Tom
Last Name: Rein
City: Saline
My guess is you are using a PVA glue like Titebond. These glues will shrink into the finish. Hot hide, fish glue, or polyurethane glue won't shrink and will stay nice and level. I used to use polyurethane but switched to fish glue since it is way less messy and far less toxic.
Stay with the happy people.
--Reynolds Large
PostPosted: Sat Nov 05, 2011 9:31 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Sometimes as everything gets nice and tight, it actually seems to squeeze the glue a little, forming a thin ridge in places. This scrapes off.
I agree with Todd, the real problem is that the guitar is built of wood.
http://redrivercanoe.ca/
Users browsing this forum: phil, stumblin and 7 guests
