It is currently Tue Jul 29, 2025 6:35 pm
 Post subject: Soundport Cut Out Method
PostPosted: Mon Oct 17, 2011 3:01 pm
Last Name: Sollod
I am thinking about doing my first soundport on my current build and I'm wondering what are the methods you guys use. I have not decided whether to make it a circle, an oval, or some other design... I have seen the use of a template clamped to the guitar with a laminate trimmer. Some folks use a hole saw and I'm sure many folks use files. What is the method you use? Any other helpful comments are appreciated... [:Y:]
www.swiftcreekguitars.com
PostPosted: Mon Oct 17, 2011 3:42 pm
Some info in this thread you might find useful: http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=20334&hilit=sound%2Aport%2A
PostPosted: Mon Oct 17, 2011 4:53 pm
Simple - No template or clamps required.
1 -Draw your shape
2 - Drill 1/8" holes inside the lines
3 - Dremmel cut out by cutting between holes
4 - Sand with sanding drum to shape
5 - Bind
Steps 1 through 4 take me about 5 minutes
PostPosted: Mon Oct 17, 2011 5:00 pm
First name: Jim
Last Name: Hansen
I drilled mine by hand and then shaped manually.
A router template would be fine, as long as you plan to build multiple guitars using the same shape. In this case they would make the process a bit quicker, and your shape more consistent.
On the other hand, if you are doing one-off designs, or don't otherwise case to repeat your shape, a template is definitely not necessary
Jim Hansen
PostPosted: Mon Oct 17, 2011 8:41 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I draw it out on cad using cross hairs , then tape to sides with the centerlines drawn and use dremel and stewmac router base to rout..finish up with sandpaper ...easy!!
MK5acoustics.com
PostPosted: Mon Oct 17, 2011 9:19 pm
Drill two 1/2" holes near each end (I like ovals) then jig saw the shape out, follow up with small drum sander in drill, then hands sand. Takes me 20 mins.
PostPosted: Mon Oct 17, 2011 10:00 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Don't do a round hole, I did my 1st sound port round and I hate it, looks like a entrance hole for a bird house. Ovals are just as easy and look much better. The paper template stuck onto the side is what I do also, I don't bind mine but that should not be a big problem to do.
Fred Tellier
PostPosted: Mon Oct 17, 2011 10:41 pm
I use my teeth
PostPosted: Tue Oct 18, 2011 1:38 am
SimonF wrote:
I use my teeth
Could you do a video or post pix?? Maybe put them in the "Fixture, Video and Picture Tutorials" section!!!
PostPosted: Tue Oct 18, 2011 1:46 am
State: Serbia
drill with various bits than use Dremel"s accessories to finish
