It is currently Tue Aug 05, 2025 8:06 am
 Post subject: v-joint tutorial
PostPosted: Fri Oct 07, 2011 3:45 pm
First name: Adam
Last Name: Vernon
City: Columbia
State: Maryland
Zip/Postal Code: 21044
I found a reference to this tutorial by Joshua French, but now I see that all the images are gone:
viewtopic.php?f=10102&t=10511
Does anyone know if the images are available somewhere? Has anyone archived the tutorial?
Thanks!
 Post subject: Re: v-joint tutorial
PostPosted: Fri Oct 07, 2011 4:31 pm
There is a Youtube video by David Schramm that gives some pointers to doing the V joint. I think he uses the Fussen joint, what some people refer to as the Hauser V. In reality that joint dates long before Hauser. There are a number of variations. I'm guessing that the J.French one was the through V - the type that Romanillos employed.
Making accurate templates helps enormously, as does seriously sharp chisels. The best advice though is to get some scrap wood and do a couple of trials, just to get the feel.
PostPosted: Fri Oct 07, 2011 4:34 pm
Try to combine with these pictures. ;)
PostPosted: Fri Oct 07, 2011 6:00 pm
Welcome to the forum.
Here's a few links for you to check out, hope they help.
viewtopic.php?f=10101&t=28080&start=0&st=0&sk=t&sd=a&hilit=joint
viewtopic.php?f=10101&t=26944&start=0&st=0&sk=t&sd=a&hilit=joint
PostPosted: Fri Oct 07, 2011 6:14 pm
There are some pictures of my method in the beginning of this thread
http://www.mimf.com/cgi-bin/WebX?14@121.eoxqav0dJgJ.2@.2cb6eac1/0
PostPosted: Fri Oct 07, 2011 7:40 pm
I did a tutorial over at Luthier Com using Joshua's procedure of hand cutting the joint. Here is a link. I had a few more pictures than Joshua did in his tutorial here.
http://luthiercom.org/phpbb3/viewtopic. ... 513d2407b1
PostPosted: Fri Oct 07, 2011 8:17 pm
Here's another take on the joint.
http://luthiersforum.com/forum/viewtopic.php?f=10117&t=21868
Users browsing this forum: Cal Maier and 35 guests
