It is currently Fri Aug 01, 2025 2:16 pm
 Post subject: help me figure this out
PostPosted: Wed Sep 21, 2011 4:15 pm
I was looking at some of Jim Olson's work here http://www.olsonguitars.com/guitar_appts.html and I love the way he does the rear headstock veneers. How is this done? Is the veneer simply cut after the neck is made or is it a v joint? Any tutorials anywhere on something like this would be quite helpful. Thanks.
PostPosted: Wed Sep 21, 2011 4:23 pm
First name: William
Last Name: Snyder
City: Brooklyn
Looks to me like he probably adds the veneer before he makes the v joint then binds everything afterward. If you want to be sure, you could ask him. I do like the look and have seen a number of other guitars done this way, though most don't go to the trouble of binding the rear.
PostPosted: Wed Sep 21, 2011 5:21 pm
OK, so I found a build thread on the AGF. It is definately not a v-joint. The veneer must be made off the guitar then the place where the veneer sits routed out? I guess it could be done with a pin router set up maybe? Do any of you guys use purfling on your rear headstock veneers with a volute?
PostPosted: Wed Sep 21, 2011 6:54 pm
Yup, CNC work there. Even with CNC, Jim's work is amazing in my opinion.
PostPosted: Wed Sep 21, 2011 7:56 pm
Yea,I don't think his work is so great...If you look really close you can see one of those miters is .00001"
off .
PostPosted: Wed Sep 21, 2011 8:08 pm
Well, everybody has an off day here and there. :)
PostPosted: Thu Sep 22, 2011 10:59 pm
I do this;
PostPosted: Fri Sep 23, 2011 9:27 am
I know that Gary Lee from the OLF does the same thing. Maybe you could PM him.
Ken Franklin
clumsy yet persistent
PostPosted: Fri Sep 23, 2011 3:21 pm
OK Jim do tell. What's the method?
PostPosted: Fri Sep 23, 2011 3:28 pm
First name: Danny
Last Name: Vincent
Jim Watts wrote:
I do this;
CNC or no CNC, that's great work Jim. That's makes me want to go out and buy CNC. In fact, I think there's a sale on at Laguna right now wow7-eyes ......... duck and running.
PostPosted: Fri Sep 23, 2011 9:29 pm
First name: William
Last Name: Rieselbach
City: Milwaukee
State: WI
Zip/Postal Code: 53211
Jim Watts wrote:
I do this;
That would be cool on both sides of the headstock!
PostPosted: Sat Sep 24, 2011 1:24 pm
It's inlaid. I cut the piece of inlay and the cavity on a cnc router. After the cavity is cut I install the purfs into the cavity, then I have to fit the inlay, but it's pretty close it's pretty close but my router doesn't hold tolerances very well. It may be made by Laguna laughing6-hehe .
It might look good on both sides, I've thought about that off and on over the years but can't quite decide. Maybe I'll try it some time.
PostPosted: Sat Sep 24, 2011 3:16 pm
I do something similar around my volutes but use the same wood as the neck(and don't use purflings). If I was going to do one like Olson's I would:
Cut the volute into the headstock first, before final neck shaping
shape my back veneer to fit tightly around the volute (I use a chisel and razor blades for this)
rout the pattern for the headstock into that back veneer registering off of the volute shaped portion
cut the channels for the binding and purfling into the back veneer and install them off of the neck. (if it is thin you are really cutting away where the channels would be and laying those outside pieces up onto the edge of the veneer)
Glue the back veneer onto the headstock
shape the facets on either side of the volute
I would guess Olson's is CNC at least partly, the tip of the volute looks rounded and I would imagine that is so he can use a bit in the CNC to shape the inside of the binding there and not have to go back with hand tools and make a point.
Burton
Brookline, MA.
PostPosted: Sun Sep 25, 2011 12:51 am
First name: Jeremy
Last Name: Pappenfus
City: Whitefish
State: MT
Zip/Postal Code: 59937
I do mine similar to how Burton described. Obviously I have a ways to go to compare to the master craftsmen that Jim is.
PostPosted: Sun Sep 25, 2011 1:39 pm
Jeremy, that looks great. I have another question about glueing a veneer on a headstock. If you already shaped it and bound it you have no wiggle room when glueing it up, meaning it can't slide. How are you guys registering your veneers? This question applies to fingerboards too....I've got a cool idea for a fingerboard but it has to be completed before I glue it to the neck, which is not how I typically do it.
PostPosted: Tue Sep 27, 2011 10:16 pm
First name: Jeremy
City: Whitefish
State: MT
Jason, the answer is fairly easy. Use the spots you'll never see. What I mean is for glueing the headstock veneers I use a template that makes each veneer the same shape, size, profile. The template is attached to the piece by two pilot holes located where the tuning mechanisms eventually are located. The template is then attached to the actual headstock and a router cuts out the same shape using the same pilot holes. Those holes are now in position that with a couple pins I secure the headstock veneers in place while I glue and clamp. The pins are then removed and the veneers are secure and exactly in place. I wish I had some pictures of these steps, but I don't yet. The other important thing is that I have multiple templates for different nut widths.
Any other questions?
p.s. I use the same technique with the fret board.
