It is currently Mon Aug 18, 2025 4:05 am
PostPosted: Mon Sep 19, 2011 3:36 pm
First name: Darren
Last Name: Figgs
Zip/Postal Code: 94519
For those of you who use double x-bracing, is the lower x-brace coupled to the top x-brace with lap joints where the two intersect and then extended to the sides? Or do you just butt the lower brace against the top brace and then butt a finger brace up against the other side?
How does coupling the two change the response of the top?
PostPosted: Mon Sep 19, 2011 4:48 pm
I just butt the lower x against the upper, and line up the finger brace on the other side.
Chuck
PostPosted: Mon Sep 19, 2011 6:00 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
Here is how I did one on a dred, haven't got the guitar finished yet so I don't yet know how it will sound...I thought this bracing scheme looked pretty cool, I think its done on some old Gibson's...
MK5acoustics.com
PostPosted: Mon Sep 19, 2011 6:02 pm
Last Name: Cox
I suppose it depends on what you want to do.... If you do couple it - you will have to decide on how to deal with the additional stiffness.... If you don't - you might end up wondering how much lighter you could have built it if you had.... or maybe it will come out fine like many others have....
I didn't couple the last one and the lower X was really lightly built... It sounds great, but it's got a couple funny sinky marks in the lower bout... Is it from coupling or not coupling the bottom X to the upper X or is it from too wide of an X or not enough bridge overlap... Not real sure... but the solution is probably within that set of things.... I will have to decide what to do different on the next one... I am leaning towards a narrower X angle.... but I am still chewing it over in my head...
PostPosted: Tue Sep 20, 2011 6:58 am
Last Name: Cox
Just for reference - here's the bracing I was talking about... It's a J45 plantilla (Dread)
Looing back at my bracing pix, the top sinkys are in the exact place where the lower X doesn't intersect the main X.... It might be worth running the lower X into the upper X - even if it's feathered down pretty thin where they hit....
PostPosted: Tue Sep 20, 2011 4:41 pm
First name: Darren
Last Name: Figgs
Thanks for the comments and photos! Yes, I think coupling them might make the top really stiff. Perhaps they might work against one another. I'll try butting them up against one another on my next one.
Thanks!
