It is currently Tue Jul 29, 2025 3:21 am
 Post subject: Radial Purflings ?
PostPosted: Thu Aug 11, 2011 8:10 pm
I can't find in the archives where how you make your radial purflings? I'm wondering after looking at last week's post if I'm doing them correctly? How thick? I'm glueing 1/8" edge grain together then in a case of a rosette I'm sanding the miters to make the turn?? How do you do yours? Also, if using edge grain would rift sawn look too wierd? Clinton
 Post subject: Re: Radial Purflings ?
PostPosted: Thu Aug 11, 2011 8:46 pm
Last Name: Ensor
City: Springfield
State: Missouri
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=31248&p=413428&hilit=radial+zebra+wood#p413428
I give a description of how I make mine here. Some install them like pearl- snapping them in. Hope this helps.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Thu Aug 11, 2011 9:16 pm
Here's how I did mine. I had a piece of Zebrawood about a foot long and 5 or 6" wide by about 1 thick. I cut it cross grain and glued the sticks end to end.
Next I glued a dark/light pair (EIR/Maple) to the edge I was going to cut first.
Then I cut the strip.
Then I glued another dark/light pair to the other side after thicknessing carefully, and cut it into strips.
First name: Evan
What is the grain orientation in a radial purfling?
Edit:
and Waddy got hit his submit button before I hit mine..........
PostPosted: Thu Aug 11, 2011 9:18 pm
After cutting and cleaning up, the sticks bent very well. Here is a rosette using the bent radial sticks.
PostPosted: Thu Aug 11, 2011 10:35 pm
Actually, mine is side grain, not end grain. The veneer pairs are glued to end grain.
PostPosted: Fri Aug 12, 2011 9:00 am
Thanks! I'll try that. I never would of thought those would bend tight enough to around a rosette. That's what I get for assuming. :roll: Clinton
PostPosted: Fri Aug 12, 2011 12:44 pm
First name: Maks
Last Name: Lavrov
Man this thread got me really excited, especially your link, Tod, to an earlier thread. You probably like that coco just as much as I! That's a first. I'll deffinately be trying that radial purfling like pearl tecgnique, can't wait! bliss
