It is currently Sat May 23, 2026 5:36 am
PostPosted: Tue Jun 14, 2011 7:49 pm
First name: Tom
Last Name: West
State: Nova Scotia
I use two .125" x.375" CF rods,each spaced about .125" from either side of the two way truss rod. They are glued with epoxy. This is a bit messy and I was thinking of going to CA. Wonder if any one does this and if they have experienced any problems.
Tom
PostPosted: Tue Jun 14, 2011 8:07 pm
I might work if you use thicker CA glue. My truss carbon rods are thickness that they come from the mfgr and my slot is the width of my bit. They don't quite match. I wear nitril gloves and use epoxy and live with the mess.
PostPosted: Tue Jun 14, 2011 8:42 pm
I've used medium CA with no problems. It can leach through the pores so I seal the slots with shellac before gluing. Masking off the surface of the neck except for the slots for CA or Epoxy helps with the mess.
PostPosted: Tue Jun 14, 2011 9:03 pm
Remember to that if you choose to use epoxy it likes a small gap of about .002.
Tape along the deges helps BTW.
PostPosted: Tue Jun 14, 2011 11:27 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
To control the epoxy mess, I lay a wide piece of masking tape along the neck surface, then carefully cut away the tape (with a sharp exacto knife) over the slots. Pull the tape before the epoxy fully sets & it's no muss no fuss.
Thin CA would almost for sure wick through the pores & show up as dark spots on the back of the neck. Medium CA might work, but I don't see it being any less messy.
PostPosted: Wed Jun 15, 2011 12:08 am
I put the two CF rods and the truss rod all in one wide slot, well-fitted, so only one side of the CF rod gets epoxied. Not as much epoxy mess that way, but some.
PostPosted: Wed Jun 15, 2011 12:53 am
Just speculating here, but with the MOE of CA being what it is, I would not want to use it in an area where movement is expected, and adjustments from initial setup point of the glue will be made during set up of the guitar. I am sure it would be fine in the short to medium term, but given this glues capacity to sheer like glass if it does fail, I would not be confident about its longevity. If you want evidence of the sheer to which I refer, try routing off the bindings of a guitar that where fixed with CA and you will see what I mean as they shatter off well ahead of the cutter. Epoxy on the other hand has 'the' perfect MOE for the job at hand....but as always when working with epoxy make sure the area is well ventilated and preferable have a fan running to push the fumes away from you. Image
PostPosted: Wed Jun 15, 2011 1:42 am
One way to avoid the mess is to glue on the fingerboard at the same time as you install the CF bars (I do).
PostPosted: Wed Jun 15, 2011 2:14 am
Last Name: Kincheloe
Has anyone tried any of the non-toxic glues, like yellow/white/hide? I ran a quick test a while back, gluing a CF rod to a scrap with a dot of LMI white glue, and it peeled off quite easily, like the glue doesn't bond well to the CF. But when it's packed into a slot, maybe it wouldn't be a problem. I'll probably just suck it up and use epoxy, but it would be nice to avoid it.
On a slightly different note... do most of you guys cut an angle in the CF rods so they can extend as far as possible into the headstock? If so, what do you use to cut the CF? Dremel cutting wheel, perhaps? I've been thinking about simply cutting the slots 1/16-1/8" deeper and adding a wood strip over the CF. That way I can get the CF just past the nut area, and plane the headstock and fingerboard gluing surfaces like normal, plus don't have to worry about getting the slot depth precisely equal to the CF height. I use a pretty hefty handstop to strengthen the nut area anyway. But burying them deeper does bring up concerns of where the CF is in relation to the neutral axis (to get maximum benefit), and cutting through to the CF when shaping the neck, if it's very deep on a thin neck.
PostPosted: Wed Jun 15, 2011 4:00 am
I always glue mine in with fish glue, works perfectly and cleans up easily. I don't use any CA or epoxy in my instruments, ever.
PostPosted: Wed Jun 15, 2011 4:13 am
I'm not quite as averse to CA and epoxy as Colin, but I too use fish glue for the CF bars (and fingerboard).
PostPosted: Wed Jun 15, 2011 4:19 am
Yes, fingerboard for me as well.
PostPosted: Wed Jun 15, 2011 6:53 am
DennisK wrote:
...do most of you guys cut an angle in the CF rods so they can extend as far as possible into the headstock? If so, what do you use to cut the CF?
Yes, and when I cut CF rods or tubes I use a hacksaw with a metal blade (and wear a dust mask…). BTW pretty much every glue will work there as the rods have nowhere to go.
I fail to see how CA will shatter, unless the neck is broken and then it is too late… Besides, medium CA tends to be softer than thin CA when cured.
I use CF rods dadoed into fretboard and neck stock for tilt-necks and use polyurethane glue to glue CF rods and fretboard, the squeeze out cleans out easily with a chisel. I've used aluminium rods for this successfully too. And I use polyurethane glue to laminate necks too. It pains my stomach, but I do.
Laurent Brondel
West Paris, Maine - USA
Last edited by Laurent Brondel on Wed Jun 15, 2011 8:47 am, edited 1 time in total.
PostPosted: Wed Jun 15, 2011 7:02 am
Colin,
can I ask, do you source your fish glue in UK?
If so, do you mind telling me where?
(Closest source I've found so far is Martin Guhl, in Germany)
PostPosted: Wed Jun 15, 2011 7:21 am
I only have used CF bars on some of the Bass's I've built. So far no problems and I never used any glue at all. Is that bad? Why glue in the bars when they fit in nice and snug?
PostPosted: Wed Jun 15, 2011 8:39 am
Colin North wrote:
Colin,
Colin, I do get mine from Germany, but from Kremer Pigmente, here's the link:
http://kremer-pigmente.de/shopint/index.php?cat=0201&lang=ENG&product=63550
One 250ml bottle will do quite a few guitars, shelf life is good so I usually get a couple of 250ml bottles at a time. I believe that Madinter has the Lee Valley glue.
PostPosted: Wed Jun 15, 2011 10:38 am
Country: Romania
Kremer. Madinter is out of stock for more than 1/2 year.
Build log
PostPosted: Wed Jun 15, 2011 3:45 pm
I have no idea of the bond strength of fish glue to CF, but you do not want to thinks of the glue as a filler.
Properly bonded in place, the CF and neck wood will act as a composite and give much greater stiffness than if it were just sitting in the slot.
But to do that, the adhesive needs to be able to transmit shear forces between the CF and the surrounding wood.
PostPosted: Thu Jun 16, 2011 6:56 am
Jeff Highland wrote:
I have no idea of the bond strength of fish glue to CF, [...]
It's poor.
I also had gotten curious about other glues than epoxy for CF and gave it a try yesterday. I glued pieces of wood with Titebond original, fish glue and epoxy to a sanded CF rod. This morning I accidentally dropped the rod to the floor and the two pieces glued with TB and fish glue just splintered off.
PostPosted: Thu Jun 16, 2011 11:53 am
First name: Tom
Last Name: West
State: Nova Scotia
Thanks everyone for the input. Markus you sealed it for me as to what glue to use.
Tom
Users browsing this forum: No registered users and 309 guests
