It is currently Tue Aug 12, 2025 6:37 pm
 Post subject: Behind Fret Noise
PostPosted: Wed May 18, 2011 8:39 am
It took me a few days to notice this but on the guitar I just finished the A string makes a noise from hitting the lower frets when I press it down on the 10th to 13th fret. It's not a buzz, it's just a brief noise from the initial contact the string makes with one or more lower frets. Otherwise, the action/set-up seems fine. Any tips on how to go about fixing this?
 Post subject: Re: Behind Fret Noise
PostPosted: Wed May 18, 2011 8:43 am
Sounds like you either need a little more relief, or your nut slots are a little low.
Also, check for a high fret. Did you level them?
PostPosted: Wed May 18, 2011 9:25 am
State: ON
Once or twice I've had some really weird buzzes as a result of frets that were not properly crowned. I thought at the time that the buzz was coming from a completely different part of the guitar (bridge area). But once I found the frets and re-crowned them it all went away. I don't know if this is your problem but it is one more thing you can check.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Wed May 18, 2011 9:26 am
The strings behind your finger are vibrating sympathetically.
Old growth, shmold growth!
PostPosted: Wed May 18, 2011 1:46 pm
It sounds like you are saying that you hear the sting slap down on back frets, but not a buzz. I think that slapping down without buzzing suggests something is really high back there. If it were only just a little too close to the strings, you would get a back buzz. The suggestions that others posted to solve a back buzz should also solve this.
PostPosted: Wed May 18, 2011 2:30 pm
Yes, it's the one string slapping down on back frets, not a buzz. As I said, it only happens when I press down the A string on the 10 - 13th frets. I haven't determined which frets are being "slapped" but, so far, the idea that makes the most sense to me is to raise the nut slot on the one string or dial in a little more relief.
PostPosted: Wed May 18, 2011 3:32 pm
Pat Hawley wrote:
..., so far, the idea that makes the most sense to me is to raise the nut slot on the one string ...
Yes, do just that. Putting more relief will change the entire neck feel and action on all strings in order to fix a problem with just one string.
Alain Moisan
(Now building just for fun!)
PostPosted: Wed May 18, 2011 5:42 pm
By the way. I happened to be traveling and playing a guitar that I was not used to. In many locations, I got noise when applying my left hand. I attributed this to the guitar being just "different" than what I was used to, and that my technique had been "honed" to my regular guitar, which I guess is my fault.
PostPosted: Thu May 19, 2011 1:34 pm
Last Name: Miranda
Couldn't it be that your frets are a little low in this area of the A string?
PostPosted: Thu May 19, 2011 9:06 pm
Perhaps for some reason, the frets are low in this particular area. I'll chase it some more on the week end.
Users browsing this forum: meddlingfool and 23 guests
