It is currently Mon Jul 28, 2025 6:43 am
 Post subject: Smaller than Martin D5
PostPosted: Thu May 12, 2011 11:02 am
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
Hai, Luthiers,...
my question is any other smaller model than Martin D5? (classical) with 6 nylon strings? And where can I get the Plan... thank's a lot... [uncle]
PostPosted: Fri May 13, 2011 10:33 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Maybe the MIMF plans would work for you...The plans for the "small guitar/baritone uke"
https://secure.mimf.com/order.htm
I'm not sure how it compares to a Martin Size 5 but it looks pretty small
PostPosted: Fri May 13, 2011 10:38 am
It's considerably smaller than the Martin Size 5 Terz.
PostPosted: Fri May 13, 2011 3:20 pm
Yes, puzzling. D5 classical?
Herry, can you clarify?
PostPosted: Sat May 14, 2011 8:52 pm
I can find no mention if a CF Martin D5 There is a D1 The size 5 is called a parlor , terz and a 1/2 size dred .
PostPosted: Sun May 15, 2011 4:25 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
I'm sorry about that false style of Martin D5, this the true syle, Summer 2009: A Martin-style Size 5 Guitar!!!
I've decided to build a cute little Martin-style Size 5 guitar this summer. This will be the fourth one I've built. The others belong to friends and family — this one's for me!
. I've known from Kathy Matsu shita.....
aah here the spec from Kathy's block:
The only other resource for the Size 5 style I've found since is Scott Antes's plan for what he calls a "3/4 Size" guitar, available at Luthiers Mercantile. It's a full blueprint, with specifications for every aspect of this guitar style.
THE SIZE 5's DIMENSIONS (approximate): Body length = 16", Upper bout = 8-1/4", Lower bout = 11-1/4", Waist = 7", Body depth at tail = 3-7/8", Body depth at neck = 3-1/8", Scale length = 21.3" (I cut off a pre-slotted, 16" radiused 25.34" scale fingerboard at the 3rd fret.), 12th fret at body.
thank's
