It is currently Mon Jul 21, 2025 3:56 pm
PostPosted: Mon May 02, 2011 5:28 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Now, what brand and grits of abrasive do I need/are the best? I'll be using this primarily for finishing. So, I'll probably be using it wet or dry.
Thanks in advance,
Phillip
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Mon May 02, 2011 5:31 pm
Envy. Jealousy.
PostPosted: Mon May 02, 2011 6:30 pm
I use 3m 30 mic 366l MDF PDA te
ID # 60-0001-2168-5
and 15mic
ID# 60-0001-2172-7
And I sand dry only.
PostPosted: Tue May 03, 2011 10:09 am
First name: Phillip
Last Name: Patton
City: Yoder
ID # 60-0001-2168-5
and 15mic
ID# 60-0001-2172-7
And you go straight to buffing after that? Sounds great. bliss
Regards,
Phillip Patton
PostPosted: Tue May 03, 2011 11:29 am
Yep, straight to buffing. But frankly I would like to be able to get one step finer. They do make a 9 mic as well, but I found that it clumped quickly and left deeper scratches than what you're trying to sand out. So it takes a bit of muscle/patience at the wheels, but the results are nice.
PostPosted: Tue May 03, 2011 12:02 pm
First name: Phillip
Last Name: Patton
City: Yoder
I see that LMI carries some:
http://www.lmii.com/CartTwo/thirdproduc ... +Abrasives
Is that what you use? I don't know if it's self adhesive, or hook and loop. It looks like the pad on the Dynabrade is hook faced.
Regards,
Phillip Patton
PostPosted: Tue May 03, 2011 12:14 pm
No, what I have is 5" discs with I think 8 holes for vacuum. I'm not sure if it comes in hook and loop. I know you can get a pad for the sander easily enough.
PostPosted: Tue May 03, 2011 12:36 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
Meddling Fool- What kind of finish are you sanding? Have you used that method on nitro? Phillip- Think about using the Dynabrade for all your sanding. I have 4 in the shop and they are the very, very best sanders for all your sanding. Extremely fast and powerful. I know you'll like it if you try it. I use PSA Mirka Gold paper. The pads on your sander just screw on and you can get any kind pads, hook & loop, PSA, PSA with holes, etc., very cheaply. Happy sanding.-Bob
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
PostPosted: Tue May 03, 2011 1:01 pm
Everything but nitro. Slow dry laquer, UV poly, ktm 9 (rotten stuff!), ktm SV (awesome stuff!)...seems to work well for everything so I don't see why nitro would be a problem. But I say that with no nitro experience.
PostPosted: Tue May 03, 2011 1:51 pm
First name: Phillip
Last Name: Patton
City: Yoder
Thanks for pitching in! I'll definitely be trying it on wood too. I'm hoping this will revolutionize my finish. Sometimes I get these deep scratches that don't show up until I've buffed. [headinwall] I think they are from finish loading up on the paper.
Regards,
Phillip Patton
PostPosted: Tue May 03, 2011 2:00 pm
Probably. I have a piece of soft carpet on the bench. I sand a bit, sand the carpet to clean the disc, repeat. I use 6-8 discs if each grit per guitar. Not cheap, but better ryan having deep scratches.
PostPosted: Wed May 04, 2011 10:53 am
First name: Phillip
Last Name: Patton
City: Yoder
Anyone else want to share their favorite ROS abrasives? I'm especially looking for hook and loop.
Regards,
Phillip Patton
PostPosted: Wed May 04, 2011 6:55 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
At a cabinet shop I worked at we used Uneeda abrasives. They cut forever compared to the one with the dog on them they used before (dont remember what brand that was) . We used the red PSA backed ones.
http://www.sandpaper.com/products/discs ... orking.asp
Darrin
PostPosted: Wed May 04, 2011 7:19 pm
That's interesting, some of their stuff goes up to 3000 grit.
PostPosted: Wed May 04, 2011 9:03 pm
First name: Orion
Last Name: Adcock
City: North
Zip/Postal Code: 76210
How many cfm is your compressor? I used those for years when I did cabinet work and they hog air. I've wanted to get one for my personal use but been afraid my compressor wouldn't keep up.
No one appreciates the very special genius of your conversation as the dog does.
Christopher Morley
PostPosted: Wed May 04, 2011 9:52 pm
First name: Phillip
Last Name: Patton
City: Yoder
I think mine's around 20 cfm. It's an old Champion 80 gallon, four cylinder, two stage 5 HP compressor. Should keep up. 8-)
Regards,
Phillip Patton
PostPosted: Wed May 04, 2011 9:55 pm
Phillip I just went to your site.....hmmmmm! That is gorgeous work!
Now what is ROS abrasives?
I have used one Dynabrade 3.5" 12,000 rpm with the small orbit since 1991! It has sanded well over 1500 rifle stocks, tons of misc items and it is still going! I don't know how fine the grit can be had, but the very best dry sanding abrasive I have ever used is Premier Red by Carborundum (sp)! With the high speed and small orbit, 400 grit is like 1200.
edited to add: Link for Premier Red plus Dynabrade http://www.abrasivesupply.com/3_1_2_PSA ... _s/116.htm
PostPosted: Wed May 11, 2011 3:38 pm
First name: Phillip
Last Name: Patton
City: Yoder
Well, my dynabrade finally got here. I'm stoked. I went out and bought a regulator, oiler, and filter/dryer. I already have a dryer installed, but I figure another can't hurt.
The sander came with the PSA pad, so until I buy a hook and loop, I guess I'll be using psa discs...
Thanks for the compliment!
ROS = Random orbital sander. Thanks for sharing your experiences. I'm sure I'll be happy with mine. :) I'm sure there will be a learning curve though. I'll practice on a cheap guitar. ;)
Regards,
Phillip Patton
PostPosted: Thu May 12, 2011 1:04 pm
First name: Phillip
Last Name: Patton
City: Yoder
I got the air system all put together, and have the sides of my current project sanded:
So far, I love the new sander!
Regards,
Phillip Patton
Users browsing this forum: dofthesea and 43 guests
