It is currently Wed Jul 30, 2025 6:37 pm
 Post subject: Brace wood
PostPosted: Sun Feb 06, 2011 12:48 pm
First name: Danny
Last Name: Vincent
I'm going to try some deflection testing on some brace wood. I'm wondering what sort of length and diameter people have been working with? I have some Sitka, Englemann, Lutz and fairly stiff Cedar to play with so I am looking forward to seeing the results. I know you don't have to be too scientific with your set up. A picture would be cool.
On the topic of brace wood, what do you guys find you get the best results with? If your not testing it, what do you look for. Grains per inch? Some of the Sitka I have has the tightest grain count on the sapwood. Wonder if that makes a difference? I'll also try some wider grain Sitka.
Danny
 Post subject: Re: Brace wood
PostPosted: Sun Feb 06, 2011 6:05 pm
I pretty much exclusively brace with Adirondack Spruce. Best stiffness to dimension ratio, which allows the most radical scalloping. Nominal beginning stock for X brace is .25" x .5"
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Sun Feb 06, 2011 10:13 pm
First name: Danny
Last Name: Vincent
Thanks for that Chas. I wish I had some Adirondack to throw in the test. When I asked about size I was referring to what a good dimension to use in a test.
Danny
PostPosted: Sun Feb 06, 2011 10:44 pm
I test lots of brace wood. I start with .75 X .32 stock for testing purposes, measure the deflecion across a 12" span and wiegh the brace stock on a gram scale. I grade my braces by their stiffness to wieght ratio not stiffness alone. I've concluded that you can't grade by spieces alone. I've had some great adirondack and some no so so hot adirondack, same with sitka, and european, engleman and lutz.
You can also learn to sort them just by tapping braces of equal dimensions, you'll get them sorted in right order but won't be able to attach any numbers to them, for ever that's worth.
PostPosted: Sun Feb 06, 2011 11:20 pm
I do, I just sort it by mechanical properties regardless of species and use it accordingly. For example, stiffest braces for things like the upper transverse brace, and X brace and I use the most flexible for things like finger braces.
PostPosted: Mon Feb 07, 2011 12:34 am
First name: Danny
Last Name: Vincent
Filippo Morelli wrote:
Anyone build tops mixing bracewood? Just wondering if anyone feels out the wood they have and picks as they see fit ....
Filippo
The last one I did had a Lutz "X" and the rest was Sitka. I have come to one strong conclusion on this combination and that is that it makes for very good guitar like sounds and still has a very definite guitar shape. :?
PostPosted: Sat Feb 12, 2011 7:28 pm
First name: Danny
Last Name: Vincent
Ok, that was pretty interesting. I used a dial on a magnetic stand on my table saw. Just a couple of 6" long 4x4's, 12 " apart and an 8lb weight. It seemed the best way to get most accurate values was to weight the ends down a bit. I tested Lutz, Englemann and Sitka, .625 x .3125. They were all pretty close but interestingly enough the higher the grain count the stiffer the wood. FWIW the Sitka had 4 growth rings and .023 deflection, Lutz, with 5 rings had .021 and Englemann, with 7 growth rings had .019 deflection. I milled a piece of cedar also but it was off the chart. I think I'll see if I have some tighter Sitka and see what the difference would be. Unfortunately no Adi or Euro to throw in. I thought I would share this because it was a new experience kind of interesting.
Have a good weekend.
PostPosted: Sun Feb 13, 2011 12:49 am
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
Port Orford cedar is supposed to be very strong, and it smells nice too. Never tried deflection testing yet.
