It is currently Fri Aug 22, 2025 9:29 pm
PostPosted: Sun Jan 23, 2011 8:01 pm
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
Hello everyone
just seen this add in my local store
should buy this since its half price (50 euros) 3 times cheaper than anywhere else around
Its 2.5 hp /24L
I was thinking it would be good idea since.... :idea: i was sanding some metal
on the belt/disc sander and it set a bit of sawdust allight
i had to take the under disc panel off to get the cinder out
(im gettin d/c soon)
Im not expecting much from it ,other than cleaning my machines
mabye a high powered fret slot cleaner
would it be suitable for anything else though
spraying in the future or small tools?
sorry about the newbie question
Thanks again
Tomas
PostPosted: Mon Jan 24, 2011 9:47 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Hi in order to use a spray gun, you have to match the cfm output of the compressor, to the cfm/s required of the spray gun. My guess , you could get by with a small inexpensive touch up spraygun . Check how many cfm/s it needs first before buying
PostPosted: Mon Jan 24, 2011 10:37 am
NO! Run away from that...
