It is currently Fri May 08, 2026 3:01 pm
PostPosted: Sat Dec 04, 2010 1:44 am
First name: Jeremy
Last Name: Pappenfus
City: Whitefish
State: MT
Zip/Postal Code: 59937
Help please!! Trying to bend some ebony binding with a basswood laminate but the darn thing keeps separating. I'm not using water, and the pipe is at a temp that I normally have great success when bending ebony. Any advice or tips?
thanks,
PostPosted: Sat Dec 04, 2010 1:57 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Hey GN. I for one, have never been able to pipe bend laminated bindings. In a Fox style bender, the laminates are held together through the heating, bending & cooling process. Even if the glue lets go , it will re-set as the joint cools.
PostPosted: Sat Dec 04, 2010 2:13 am
Last Name: Kincheloe
Have you tried with water? I had no trouble bending LMI's curly maple w/ rosewood lam on a pipe, dipping my hand in water and rubbing along the wood to wet it just before bending, and re-applying frequently as the pipe dries it off. Well, some splitting on the curls, but no delamination. Maybe being so gentle due to the curls helped avoid peeling the glue apart even if it did soften? Ebony may need to get hotter though, which would increase risk of delamination.
PostPosted: Sat Dec 04, 2010 10:40 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
Well I'll let you know how my binding bend goes next week. I purchased the same ebony laminate bindings from LMI for a Cocobolo build and NOW... will probably also wait to route my channels until I know the bends went OK...
Kent
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Sat Dec 04, 2010 10:49 am
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
The basswood separates a little bit from the ebony in the waist bend for an OM, even in a Fox style bender, on some pieces. Allow enough binding pieces so you can screw up some of them. At least that's how it goes for me.
Chris.
PostPosted: Sat Dec 04, 2010 11:20 am
First name: Jeremy
City: Whitefish
State: MT
Thanks everyone. Wondering if it would work to bend them on the pipe as a group like you would with a bending machine. Figure a way to bind them all together where the waist bend will be so they help stay sandwiched. Thoughts??
PostPosted: Sat Dec 04, 2010 11:21 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Try bending all you pieces at once. Tape then together tightly, with the purfling on the inside.
PostPosted: Sat Dec 04, 2010 11:26 am
First name: Jeremy
City: Whitefish
State: MT
Thanks, thats what I'm thinking. I also wonder if wrapping the bend with tin foil will help ease the bend and lessen the chance of a broken piece?
PostPosted: Sat Dec 04, 2010 7:48 pm
I<ve had the best results with using Titebond III to glue the side purfs onto the binding, Holds great even on pipe bending.
PostPosted: Mon Dec 06, 2010 3:42 pm
First name: Aaron
Last Name: Craig
State: Missouri
Ditto. Remember to put purfling against purfling (i.e., binding, purfling string, purfling strip, binding, binding, purfling strip, purfling strip, binding) so that you have two for the top and two for the bottom. Also, I here tell a steel spring slat or flashing as a backer when bending this way on a pipe is useful for avoiding cracks. Good luck.
Aaron Craig
PostPosted: Mon Dec 06, 2010 9:09 pm
It all just sounds like a pipe dream, to me! bliss bliss
Old growth, shmold growth!
PostPosted: Tue Dec 07, 2010 1:05 am
First name: Jeremy
City: Whitefish
State: MT
Thanks everyone, did as recommended and had good results. Bent six at once taped together, wrapped in foil and with a metal backer. Only broke one (run out).
Thanks again, you guys rock!! bliss
