It is currently Sun Aug 17, 2025 8:35 pm
PostPosted: Sun Oct 24, 2010 7:50 pm
So I’m getting started on my second build, a Martin style EIR / red spruce dreadnought for my youngest son. My first was a very similar dread for my older son but was built from a Martin kit, whereas this one will be mostly a scratch build.
One of the things that had me worried was thicknessing the rosewood since the only tool I have with which to do it is a #4 bench plane. Well, this morning I sharpened up the blade and went at it, and to my surprise it wasn’t bad at all. In fact, I actually really enjoyed it! There’s something satisfying about a really sharp blade cutting through a wood as dense as rosewood and producing those fine shavings.
Anyway, I know a lot of folks use a drum sander, but I was wondering how many builders thickness their backs and sides with the trusty old hand plane.
PostPosted: Sun Oct 24, 2010 7:54 pm
First name: Evan
Last Name: McCartney-Melstad
Yup, Stanley #4 for me too--it goes quick. Though if I had access to a thickness sander I'd probably be all over it.
Evan McCartney
PostPosted: Sun Oct 24, 2010 7:58 pm
Yeah, I can definitely see a thickness sander in my future, but I pleased (and relieved) to know it can be done pretty easily by hand in the meantime. bliss
PostPosted: Sun Oct 24, 2010 8:13 pm
I think if I had a good plane, I'd get the plate to 85% thickness and then finish it off in the sander to correct any probable thickness irregularities.
PostPosted: Sun Oct 24, 2010 9:23 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I use drum sander because I have a free access to it at school, and because the teachers want us to use it but.. In fact, once I'll start to build in my own shop, I'll buy a good #4 and go with it.
By the way, are you using straight blades or also a toothed one?
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sun Oct 24, 2010 9:38 pm
First name: Evan
I use a #4 with an untoothed blade because that's what I have. I'd like to try with a 5 or a 5 1/2 with a toothed blade at some point--I think the tooth could help keep things even.
Evan McCartney
PostPosted: Sun Oct 24, 2010 10:23 pm
City: winnipeg
State: manitoba
Country: canada
I saw a jig that uses a router to thickness most of the way. It was a cross between the router arrangement used to make radius dishes (but level) with a rising table like a drum sander. It was pretty simple to build and would be adequate for onesy-twosy builders (like me).
I only use my drum-sander a couple of times a year and now I have to build a bigger one to handle a cello soundboard.
Bob :ugeek:
PostPosted: Mon Oct 25, 2010 3:28 am
First name: William
Last Name: Stewart
City: Hawick
State: Roxburghshire
Zip/Postal Code: TD9 9NB
Country: Scotland
The method that I use I would not recommend to anyone. I use my Bosch electric hand held planer for the initial thicknessing. I get down to just over 3mm and then finish off on my home built thickness sander. The reason I do this is because of my arthritis. My joints can get pretty painful after a days work with hand tools. I set the planer to its lowest setting and and very carefully do light passes at an angle to prevent chip-out. Not for the faint hearted.
WARNING!...DON'T DO THIS AT HOME!
Bill S.
Dream to be a luthier
PostPosted: Mon Oct 25, 2010 5:57 am
You can also use a Wagner Safe-T-Planer to quickly and accurately bring sets down to specs, just leave enough to clean up with abrasive (not much mind because the finish is quite clean with a sharp tool) and it will save a lot of grunt and dust.
PostPosted: Mon Oct 25, 2010 7:13 am
I use a woodie to remove the bulk of the material, set to take decent thickness shavings without too much tear out. I then switch to a N0. 4 (or even No.5) for the final thicknessing. Having 2 or 3 planes that are very sharp helps to speed things up.
PostPosted: Mon Oct 25, 2010 7:53 am
I used a #5 plane with a Hock blade for 3 or 4 of my earliest guitars. It resulted in me learning how to sharpen irons properly and how to properly use a plane. It also prompted me into buying a drum sander!
PostPosted: Mon Oct 25, 2010 9:26 am
First name: Corky
Last Name: Long
City: Mount Kisco
Drum sander for me.
It only took a couple of days with some figured walnut to prove to me that my technique with a hand plane wasn't up to the task.... nothing like tearing out a few chunks of figured walnut in a beautiful back to give your vocabulary a workout. wow7-eyes
I'm better at setting up my planes now, but I love the ease and consistency of using the drum sander. I won't be going back.
PostPosted: Mon Oct 25, 2010 9:44 am
Planes and disk thickness sander and scrapers to clean up.
PostPosted: Mon Oct 25, 2010 9:30 pm
Thanks for all the responses.
Francis – just a straight blade. I don’t have a toothed one, although I probably should make one before I do it again. I didn’t have any significant tearout but based on others’ experiences it sounds like I got lucky. I may not next time. :|
I also don’t have a drill press so I can’t use a Safe-T-Planer, but a drill press is probably the first power tool I’ll buy.
PostPosted: Mon Oct 25, 2010 9:45 pm
Stanley #5
Home made thickness sander= a piece of flat ply with 3M 40 grit glued to it!
PostPosted: Tue Oct 26, 2010 1:59 am
Well I'd sell my body to a marauding pack of scantily dressed beautiful young women and let them get me drunk and have their wicked way with me before I'd even consider selling my drill press..yep, too right and fair dinkum that's how strongly I feel about that.
PostPosted: Tue Oct 26, 2010 7:33 am
Where do we line up to refuse to sell our drill press Kim?
I'm willing to suffer for my art also! laughing6-hehe
Joe
PostPosted: Tue Oct 26, 2010 9:14 am
Wow, I need to get me a drill press and move to Australia!! wow7-eyes laughing6-hehe
PostPosted: Tue Oct 26, 2010 1:28 pm
@Kim:
Hi, do you use your safe-t-planer just for the sides or also for the back ? In this case is you drill large enough to reach the centre of the back (glued line)?
thank you
PostPosted: Tue Oct 26, 2010 3:47 pm
Last Name: A
Antonio wrote:
@Kim:
thank you
The safety planer reaches - and I have a 10" drill press. Fairly small. The Safety planer is about 3 inches I believe.
PostPosted: Wed Oct 27, 2010 3:58 am
John. thank you for answering. Do you think this could do the job?
http://www.axminster.co.uk/axminster-ax ... rod719353/
PostPosted: Thu Oct 28, 2010 9:51 am
There's nothing like the pleasure one can get by making shavings with a nice sharp plane. I use a Marples jointing plane. Having said that, most of my stuff goes through a bench planer first then gets finished off on the drum sander. I'll never go back to hand planing everything again :mrgreen:
