It is currently Wed Aug 13, 2025 12:08 pm
PostPosted: Tue Sep 21, 2010 12:51 pm
So I was dry sanding my finish to knock down some dust nibs then I wiped the sanding dust off with a paper towel damp with mineral spirits. The finish seemed to get a little soft so I hung it up and let it dry off when I read the can duh . It said not to use mineral spirits to clean. So did I screw it up or will it probably be fine if I just let it sit for a while before I proceed with the rest of my coats. I don't think I have the mental strength to do it over again as this is the second finish this guitar has received.
Jason
PostPosted: Tue Sep 21, 2010 1:21 pm
Hi Jason
I use mineral spirits on dry EM600 all the time when I am final sanding. I think it should be fine.
You might want to post your question on the Target forum. People there may have a better answer for you.
Here's the link:
http://www.targetcoatings.com/forum/
Neil
PostPosted: Tue Sep 21, 2010 1:27 pm
Thanks Neil. I have the same question posed to the Target forum. I'm just worried about adhesion issues with my subsequent coats. Also, I thought about shooting a coat of shellac just in case.
Jason
PostPosted: Tue Sep 21, 2010 2:13 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Jason,
I have started wiping my projects down with a 50/50 mixture of denatured alcohol and water between coats. This does soften the finish a bit and helps with burn-in of the subsequent coats. I don't think you will have any issues as long as the solvent has fully flashed off before you re-shoot.
Ken
http://www.casperguitar.com
PostPosted: Wed Sep 22, 2010 11:29 am
Neil Gardiner wrote:
Hi Jason
Neil
I also do this and have experienced no problems. I do not wet sand until the finish has cured for at least 5 days. I wipe down between coats with a rag dampened with distilled water.
