It is currently Wed Aug 06, 2025 2:32 am
 Post subject: Coloring Z-Poxy
PostPosted: Wed Sep 15, 2010 8:54 am
First name: Damon
Last Name: Wack
State: FL
Switching from ColorTone filler on my next box, I have been using the ColorTone stain to color the filler. I am thinking instead I might mix a little fine sawdust in with the Z-Poxy to darken it.
Thoughts?
Damon Wack
https://www.facebook.com/LindamonGuitars
 Post subject: Re: Coloring Z-Poxy
PostPosted: Wed Sep 15, 2010 10:26 am
I too was wondering why you are dyeing the epoxy, unless you want the pores to show.
PostPosted: Wed Sep 15, 2010 11:45 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Try Z-poxy on some scrap tonewood and you will see as stated already no color is needed, it makes the wood come to life all alone. It is best to practice a little at 1st as it can be a little frustrating if you leave too much on when you apply. Watch the video Todd did and note how much he applies at the start, I learned the hard way how little is needed, too much will lead to lots of sanding.
Fred
Fred Tellier
PostPosted: Wed Sep 15, 2010 1:35 pm
First name: Damon
Last Name: Wack
State: FL
Cool. I will try it on scrap first, I assumed that like when using the colortone filler, filled pores look better when dark, as open pores in wood naturally look darker because of the shadowing effect. Since the epoxy filler is clear I guess it would make sense the shadow effect would still occur. But I will try it on scrap and see which I like better!
thanks!
Damon
Damon Wack
Users browsing this forum: No registered users and 39 guests
cron
