It is currently Sun Jul 27, 2025 12:58 am
 Post subject: Wetting with Naptha
PostPosted: Wed Sep 15, 2010 8:43 am
I've seen several recommendations to wet wood with naptha to see the grain or find tiny scratches in finishes that still require sanding or polishing out. So I tried this. Works great - for about a second until the naptha evaporates. How do you use this stuff in a way that makes it last long enough to see anything?
 Post subject: Re: Wetting with Naptha
PostPosted: Wed Sep 15, 2010 8:47 am
Use mineral spirits, or turpentine.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Wed Sep 15, 2010 8:50 am
First name: Corky
Last Name: Long
City: Mount Kisco
I lightly mark (usually circle the offending scratch) with some of my kids' chalk - doesn't mark the wood, but shows me where to work once the naphta evaporates.
PostPosted: Wed Sep 15, 2010 10:21 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Pat,
Betenol on Innis Rd. near Bantree has a low odor mineral spirits type solvent which is nice to work with although I can't say I've used it for what yu are asking, but it should last longer than naptha.
Mike McNerney
PostPosted: Wed Sep 15, 2010 11:20 am
First name: Aaron
Last Name: Craig
State: Missouri
Can you use DN alcohol, or will there be adverse consequences? Not trying to high-jack the post, just thought someone will have a quick answer?
Aaron Craig
PostPosted: Wed Sep 15, 2010 11:35 am
Sometimes DN Alcohol will leave a white film on the wood as it dries.
PostPosted: Wed Sep 15, 2010 12:41 pm
Wetting with alcohol, lacquer thinner, acetone and other strong volatile solvents is highly discouraged: it will smear rosewood oils (and other oily woods) on your top and pretty purflings. Turpentine and petroleum based solvents do not do that, at least not to an extent where it spoils the work.
Laurent Brondel
PostPosted: Wed Sep 15, 2010 1:02 pm
First name: Aaron
Last Name: Craig
State: Missouri
Very good to know. Thanks.
Aaron Craig
PostPosted: Wed Sep 15, 2010 3:09 pm
Thanks all. I will have a look for low odor mineral spirits.
PostPosted: Wed Sep 15, 2010 10:12 pm
I've used both and I prefer the naptha. It is gentler on the wood.
