It is currently Tue Aug 12, 2025 4:31 pm
PostPosted: Fri Jul 30, 2010 9:03 am
First name: Martin
Last Name: Lane
City: Grand Rapids
So a spare small drop of walnut oil dribbled thru my soundhole into the innards of my new mahogany guitar (gonna be delivered to its owner in 2 weeks) and left a slightly bad-looking discolored area. what can I do work it out?
would it be harmful to, say, lightly spread walnut oil all around in there so it's at least homogenous?
"...you have to get over your strict adherence to your largely imagined notion of absolute perfection..."
PostPosted: Fri Jul 30, 2010 10:59 am
Will it not sand out?
PostPosted: Fri Jul 30, 2010 11:55 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
The walnut oil will probably sink in quite deeply. You may not be able to sand it out.
Will your label cover the spot? If not, I'd be tempted to lay a coat of a drying oil (Watco or Tung oil) finish on the visible area to blend it in.
Have you tried removing the spot with naptha?
PostPosted: Fri Jul 30, 2010 12:43 pm
First name: Martin
Last Name: Lane
City: Grand Rapids
It will not sand out. It's not a deep discoloration, but just enough to be sorta visible and sorta annoying-looking. It definitely doesn't look 'professional.'
Naptha is a great idea. I'll try that next.
PostPosted: Fri Jul 30, 2010 2:08 pm
First name: duh
Last Name: Padma
Pour more
down her throat
swish it around
and pour it out.
Ya know, you may have accidentally found
the new "sound" that everybody will be after.
Anyways a bit of oiling her up couldn't hurt.
blessings
be
duh Padma
PostPosted: Fri Jul 30, 2010 2:57 pm
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
I fine felt tip sharpy...smiley face in the drip and a signature. It will be conceived as the makers happy OK mark on the extraordinary great back construction.
Or......I spray a coat of shellac on the inside back and sides before putting on the top. It may not be proper...but this problem wouldn't be a problem right now.
Kent
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Fri Jul 30, 2010 3:08 pm
Before making it worse, I think I'd be checking with the customer (email/good picture??).
Milton, ON
PostPosted: Tue Aug 31, 2010 12:49 pm
First name: Martin
Last Name: Lane
City: Grand Rapids
Well, the good news is, it kind of just went away all by itself. apparently walnut oil spilled on bare mahogany appears to discolor it at first, but then weeks later, dries to the point of being nearly invisible.
PostPosted: Wed Sep 01, 2010 12:33 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Dude....that's why they invented labels. Just cover it up bliss
cron
