It is currently Wed Aug 13, 2025 10:28 pm
PostPosted: Fri Sep 24, 2010 2:07 pm
First name: Aaron
Last Name: Craig
State: Missouri
I was wondering whether you sanded your tops prior to finishing or scraped them. I am working on my first, and it seems like sanding the sitka spruce leaves wavy lines that I don't really like. Do you scrape to get rid of these lines or do I just have a strange top? Thanks.
Aaron Craig
PostPosted: Fri Sep 24, 2010 2:29 pm
Scraping softwoods can be very difficult. Do you use a block? I usually sand cross grain with a flat block, and along the grain for the last strokes.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Sep 24, 2010 2:36 pm
First name: Aaron
Last Name: Craig
State: Missouri
I do have a block and I can try that. Thanks.
Aaron Craig
PostPosted: Fri Sep 24, 2010 3:09 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
What Laurent said...
I wipe the parts with naptha & check closely for scratches before spraying. Hold the parts up to a strong light at a low angle & check while the naptha is still wet.
I only sand across the grain on softwoods. Always with the grain on hardwoods.
PostPosted: Fri Sep 24, 2010 4:44 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Also, don't use much (or any) pressure when sanding. Let the sandpaper do the work.
PostPosted: Fri Sep 24, 2010 6:01 pm
I've find the best sanding block for surface prep to be a wood block with 1/8" layer of cork glued on.
PostPosted: Fri Sep 24, 2010 8:25 pm
First name: Tom
Last Name: West
State: Nova Scotia
I see two folks mention sanding across the grain for the top,have never tried that approach. I wonder what is the benefit...?
Tom
PostPosted: Sat Sep 25, 2010 12:22 am
First name: Corky
Last Name: Long
City: Mount Kisco
Tom
Large variation in the hardness of the slow and fast growth lines of the annual growth rings. Sand with the grain and the softer part will sand faster, leaving a corduroy effect. Across the grain doesn't.
PostPosted: Sat Sep 25, 2010 6:30 am
Country: Romania
Heavy scraping tends to create a specific corduroy texture which will look distinct from a sanded surface with a thin finish such as shellac. Most people would frown at it, while in violin world it is the other way around - a smooth sanded surface is considered the sign of cheap instrument.
Build log
PostPosted: Sat Sep 25, 2010 2:38 pm
I prefer to glue the paper to the block for finish sanding. Rubber cement allows changing the paper, or get adhesive backed paper, or use doubled sided carpet tape.
Users browsing this forum: Bing [Bot], DennisK, J De Rocher and 26 guests
