It is currently Tue Aug 12, 2025 9:19 am
PostPosted: Fri Aug 20, 2010 6:19 pm
OK - I need some help identifying this wood. I was at a local hardware store that has a small section of lumber. I will occasionally browse through the lumber to see if I can spot any spruce boards for possible bracewood, but being in the southeast, the majority is some sort of pine. I spotted two 2 x 4 studs in the store that were almost perfectly quartered, straight grained, and looked very much like some spruce, so I bought them. They are stamped with a W WP which I now know stands for Western Wood Products and also were stamped with ES LP which, according to their website, means lodgepole pine. Apparently Engelmann spruce and lodgepole pine are grouped together for grading purposes. Can someone who's better at wood identification please tell me if this is in fact Engelmann or if it's LP. Both boards are very straight grain, very pale white and fairly clear of knots. I've attached some pics if that'll help. Thanks.
PostPosted: Fri Aug 20, 2010 6:43 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I doubt that anyone will be able to say what kind of wood you have there.
At any rate, that wood grew pretty quickly as told by the growth rings
and probably not stiff enough for an instrument.
PostPosted: Fri Aug 20, 2010 6:50 pm
Not sure what you mean by not being stiff enough for any instrument. I know of several people that procure there brace stock from 2 x 6's from Lowes, HD, and such. The difference, though, is that there much more adept at identifying the differences between black spruce, white spruce, doug fir, etc. than I am. All I know is that they were both perfectly quartered which is very rare in a 2 x 4 stud, very straight grained, and clear. I was just hoping to get some back and possibly top braces from them.
PostPosted: Fri Aug 20, 2010 7:00 pm
Last Name: Abercrombie
If you have some known brace wood on hand, you could just compare it with your 'find'- cut a brace from known stock and from your new sample-same dimensions- and compare their weight and stiffness. For that sort of 'test' you don't need anything fancy - just clamp the two sticks to the edge of the bench and hang a weight (pipe wrench ?) from each brace. Measure the deflection.
If it compares well, go ahead and use it!
PostPosted: Fri Aug 20, 2010 7:21 pm
That makes sense. It's very nice looking stuff and it rings like a bell when I rap it with a knuckle.
PostPosted: Sat Aug 21, 2010 7:46 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
You've already said it rings nicely when tapped. If the stiffness, and weight are right for bracing use it. It doesn't matter what species it is. A guitar doesn't know.
PostPosted: Sat Aug 21, 2010 9:29 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
Looks like lodgepole to me.
KB
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Sat Aug 21, 2010 10:10 am
First name: duh
Last Name: Padma
What difference does it make?
If it gets the pig clean ~ use it.
duh Padma
PostPosted: Sat Aug 21, 2010 11:02 am
If using sawn wood for brace stock, be sure to check for runout. Quartered, clear, and straight is nice but being free of runout is just as important, maybe more.
http://www.chassonguitars.com
PostPosted: Sat Aug 21, 2010 11:23 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
It's hard to tell from a picture, but the smell will give you the answer. Pine smells, well... piney.
Engelmann has a distinctive smell. Hard to describe, but I've heard it described as a popcorn scent. If you have an Engelmann top around, you can compare.
PostPosted: Sat Aug 21, 2010 11:46 am
Thanks for all the replies and help. I'm definitely going to split it and check the runout. If the split runs pretty straight, the wood is strong, and it rings like a bell, I guess it doesn't matter what it is.
PostPosted: Sat Aug 21, 2010 3:24 pm
First name: duh
Last Name: Padma
Yay! Now yer gettin the big idea.
blessings
duh Padma
PostPosted: Sun Aug 22, 2010 5:56 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Quote:
"JeremiahB." Can someone who's better at wood identification please tell me if this is in fact Engelmann or if it's LP. Both boards are very straight grain, very pale white and fairly clear of knots.
No one can really do this from a picture, other than a high-resolution cross-section photo. Get out your hand lens, make a very clean cut on the end grain and follow along ...
"hard" pines (including lodgepole): longitudinal resin canals numerous, quite evenly distributed in the outer portion of every growth ring, generally visible to naked eye as dark-or light-coloured dots or as small openings, relatively conspicuous with a hand lens; transition from earlywood to latewood more or less abrupt
eastern spruces (including Englemann): longitudinal resin canals generally sparse, unevenly distributed, sometimes absent, invisible or barely visible and not conspicuous with hand lens; latewood not pronounced, transition early to latewood gradual
Source: Panshin, A.J. and de Zeeuw, C. 1970. Textbook of wood technology. 3rd Edition. McGraw-Hill.
If you have other known samples of "hard" pines (not white or "soft" pines) and eastern spruce (not Sitka), you should be able to understand the above features and make the identification.
Good luck!
Quote:
PostPosted: Mon Aug 23, 2010 10:54 pm
Last Name: Cox
The biggest thing I noticed is that some 2x4 wood strongly resembles Spruce top wood and some doesn't.... Eventually, you get the hang of picking out the Pine and the Fir from the Spruce.... Or... Buy some Bona-fide "Spruce Split Brace Wood" and use it to compare against....
Personally -- I have made all the bracing from split out dimensional lumber in all of my guitars so far (3 finished, 2 more on the way) ..... The *KEY* that is absolutely critical -- split it out.... You never know what sort of evil lurks under the neatly sanded surface of an SPF 2x4..... and so for a Pro-builder... It's likely a waste of time.... Hours spent picking through the stack, only to find 0 likely candidates.... BUT... It can be good practice for us Amateurs -- we need to learn better how to "Read" the grain on a piece of wood....
You really need to see this when you split it out....
And not this:
PostPosted: Tue Aug 24, 2010 2:38 am
First name: Kirby
being from Nevada I lumped lodgepole pine in as Pondarosa pine...
a 1 meg pdf illustrates an I.D. key
http://www.faculty.sfasu.edu/mcbroommatth/Lectures/Wood_Science/Lab_2_Resin_Canal_Species.PDF
tis near wantin to say its pondarosa pine is where me mind seems to be stuck at...
never smelled engelman that had much of a pine smell.
"It's a Tone Faerie thing"
First name: Kirby
First name: Kirby
oops idunno idunno dubba post...
Users browsing this forum: stumblin and 42 guests
