It is currently Tue Aug 12, 2025 4:02 am
PostPosted: Thu Aug 19, 2010 12:45 pm
Hi everyone
As a follow up to my questions about spraying equipment, I found a pretty good HVLP gun that requires 6.2 cfm. There is also available at the same store (Home Depot) a Dewalt compressor (http://www.dewalt.com/tools/compressors ... 55168.aspx) that is rated at 5.4 scfm at 90 psi. I can't find an accurate (and simple way) to convert the 2 to see if that compressor will fit the bill for that specific gun.
Does anyone know how to convert the 2 and determine if this compressor will work?
Thanks in advance
PostPosted: Thu Aug 19, 2010 1:07 pm
Pat, The "s" in scfm stands for standard temperature and pressure. Standard pressure is sea level and temperature is probably 68.
So if you live at or near sea level, you probably don't need to worry about the difference.
I live at 7000 ft, so I would need about 25% more cfm to be moving an equivalent volume of air. I arrived at that by just looking at the difference in air pressure between sea level and 7000 ft.
Hope that helps.
PostPosted: Thu Aug 19, 2010 1:11 pm
Hi Pat .. 6.2 CFM for the gun, but at what pressure ??? I have never seen a gun that uses more than about 40-45 PSI .. so I am guessing that compressor will run that gun easily, as it probably delivers about 8-9 CFM at 40 PSI
PostPosted: Thu Aug 19, 2010 1:32 pm
Hey Guys
Thanks Jim. I live at approx 200 ft above sea level, so I guess that is settled.
Tony: I forgot to include that it is 6.2 cfm at 40 psi for the gun. As the guy in the store suspected (he said he wasn't sure about it so he recommended I get a better opinion), 5.4 scfm at 90 psi should be well above 6.2 cfm at 40 psi.
Many thanks
PostPosted: Thu Aug 19, 2010 1:34 pm
Check with the compressor manufacturer. I bet they have the full specs on the unit. Most show both a high pressure CFM and a lower pressure CFM. The one thing you don't want it for it to run all the time to keep up, so some excess CFM is pretty important for the unit in use.
PostPosted: Thu Aug 19, 2010 2:14 pm
A spray gun only has its trigger pulled about half of the time when spraying a small object like a guitar. And the whole coat only takes a couple of minutes. These breaks allow the compressor to catch up. Also the tank serves as a reservior. So in reality you can use a much smaller compressor than you'd think. I have been using a little 2 hp, 5.5 cfm unit for 30 years and it has never failed to keep up with tools often rated up to 10 cfm.
PostPosted: Thu Aug 19, 2010 3:39 pm
Barry said:
I was wondering about that. What kind of gun do you use, and how big is the tank on your compressor?
PostPosted: Thu Aug 19, 2010 5:54 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Thanks Barry. I've typed that so many times in the past my fingers are tired [:Y:]
I've got a big compressor (5 HP 2 stage) I rarely turn on. I spray with a 2HP with a 20 gallon tank. Walcom EGO or Sharp FX1000 guns, depending on material.
PostPosted: Thu Aug 19, 2010 11:03 pm
Last Name: Abercrombie
Pat-
If you just think of the situation without worrying about 'flow', it's pretty simple. If you halve the pressure , keeping temperature constant, the volume of a gas will double. So 5.4 cu ft at 90psi will be about 11 cu ft at 45psi.
In real life, the diameter and length of the hose will affect the results at the gun end, but you should be fine with the smaller compressor.
When you decide to get that air sander that needs 10cfm @90psi, then you will need a compressor upgrade....
PostPosted: Fri Aug 20, 2010 7:40 am
Hey guys
This is the gun I am looking at:
http://www.shopbot.ca/ps-campbell-hausf ... 59523.html
PostPosted: Fri Aug 20, 2010 8:16 am
Pat, my compressor is a Speedaire and it has a 20 gallon tank.
My spray gun is a Walcom STM and I think the rating was about 6cfm.
I noticed that the STM is no longer sold and seems to have been replaced by the Walcom ES/RV which is rated at 1 to 2 cfm. That sounds like an efficient gun.
PostPosted: Fri Aug 20, 2010 11:40 am
Todd Stock wrote:
A compressor will deliver more air at the lower pressures used for HVLP conversion guns, but it's not linear due to a whole host of reasons. A 5.5 SCFM@90 psi rated compressor will likely deliver 25-30 percent more air at 40 psi, so perhaps 6.8-7.1 SCFM.
I was assuming that the compressor regulator would be set at 90psi and the gun regulator would control the gun pressure.
The relationship between pressure and volume at constant temperature is quite linear
http://en.wikipedia.org/wiki/Boyle%27s_law
As the under-40s say....'whatever'.....
PostPosted: Fri Aug 20, 2010 3:20 pm
John,
The linear relationship you refer to is theoretically correct, but it does not apply to a compressor. All compressors and pumps have a performance curve that shows a non-linear relationship. This is due to the frictional resistance that increases at the higher rates.
PostPosted: Sat Aug 21, 2010 5:54 am
Todd Stock wrote:
... I did just enough aerodynamics and viscous flow courses in college to understand just how little I know about what really happens inside a compressor or jet engine or rocket nozzle, and how often the real world surprises.
As a EE taking flight test engineering courses I found that things sure do get complicated real quick. Not to mention, the math wow7-eyes
Users browsing this forum: No registered users and 47 guests
