It is currently Mon May 11, 2026 11:28 pm
 Post subject: Source for sandpaper
PostPosted: Mon Aug 16, 2010 10:10 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I came across an ad in our local Kijiji ( like craigs list in USA ) for some sandpaper and almost ignored it. That would have been a big mistake, the stuff is great and the price was great. I now have probably 5 or more years supply. My informed buddy PaulK from the forum and he had ignored the ad but has also stocked up and will probably get more.
Here is the info
This guy here in Windsor Ontario used to have a plant to cut, process and distribute Joest abrasives to North America here which he closed recently. He is selling the remaining products for $13 per hundred sheets 5" and 6" plus some uncut 1 meter wide roll stock. I just bought $160 worth and thought it might be a good opportunity for everyone. He has from 80 up to 1500 grit. This is a perferated hook and loop foam or non foam backed paper to use with vac system. If this is of interest to any of you can call him at 248 765 6345 begin_of_the_skype_highlighting              248 765 6345      end_of_the_skype_highlighting or check this ad to email him http://windsor.kijiji.ca/c-buy-and-sell-tools-equipment-Sandpaper-W0QQAdIdZ223306470
He deals in Canada and USA so shipping to either will not be a problem. He is still their distributor but when the leftovers are gone the price will be a whole lot higher.http://www.joest-abrasives.de/ is a link to the type of product he is selling.
If you contact him let him know Fred and Paul recommended him to you
Fred
Fred Tellier
 Post subject: Re: Source for sandpaper
PostPosted: Tue Aug 17, 2010 12:13 am
Last Name: Abercrombie
Thanks, Fred.
These are 5"and 6" disks, not sheets - is that correct?
PostPosted: Tue Aug 17, 2010 7:48 am
First name: Fred
Last Name: Tellier
City: Windsor
Sorry I didn't specify, yes disks
Fred
Fred Tellier
PostPosted: Wed Aug 18, 2010 11:49 am
First name: Fred
Last Name: Tellier
City: Windsor
One of the uses I had in mind for these products was RO sanding of my lacquer finish with a vac hose to the sander. I did the 1st flattening of my finish on the current build using the sander and 500 grit and it worked real well does not load up the paper as much as without the Vac. but the 500 was too fine for 1st step of the leveling so I have ordered some 400. OLF member PaulK who is a Pro Custom Furniture builder has also tried this product and has found the grits on this paper a little finer than expected. For me I like this as the finest available is 1500 and I was concerned about it being too course as a final grade before buffing. Now I think I will have no problems using the 1500 then buffing.
When he drops of my 400 later today I will have enough paper for guitar work for a long time. I love the Vac sanding no dust and much less messy than wet sanding.
Fred
Fred Tellier
PostPosted: Wed Aug 18, 2010 12:12 pm
Thanks again for the tip, Fred.
I put in an order yesterday- Robert Seke (the sandpaper seller) sounds like a very reasonable guy.
Using the vac is something I should do more often when sanding (in addition to rolling up the garage door...) . It extends the paper life quite a lot, as you are not sanding dust.
For fine finishing before buffing, I like the Abralon pads, which I get from WoodEssence in SK. They are foam and washable/rinsable.
Users browsing this forum: No registered users and 320 guests
