It is currently Tue Jul 29, 2025 9:36 pm
 Post subject: Fancy Sound hole covers.
PostPosted: Thu May 20, 2010 6:39 pm
First name: Jonathan
Last Name: Coleman
City: Lacona
Zip/Postal Code: 13083
a freind of mine asked me to make him a couple sound hole covers that match the wood of his guitars as the rubber ones dont fit (and are god awful ugly)
can someone direct me to where I go about doing this? thank you in advance!
PostPosted: Thu May 20, 2010 7:50 pm
Last Name: Abercrombie
This is to try to reduce feedback in a stage situation?
Black actually looks more 'natural, but anyway- I'd probably go for a chunk of soft foam with a piece of flexible veneer stuck to it. Just fold the veneer, insert the whole thing through the soundhole and let the sponge push the veneer against the soundhole. I do this sort of thing with a plastic lid and a sponge when spraying finishes on guitars.
It won't do much for the acoustic sound, but that's not the point, I guess.
PostPosted: Thu May 20, 2010 10:37 pm
First name: Tracy
Last Name: Leveque
State: CO
How about these: http://www.LuteHole.com/
PostPosted: Sat May 22, 2010 5:45 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've made several for soundholes that aren't the "standard" 4". Use whatever kind of wood you want (or even a piece of formica). Cut it 1/4" to 3/8" bigger than the soundhole. Notch it for the fingerboard if necessary and glue a piece of carpet padding to keep it in the soundhole. If you cut the padding right it will snap into the soundhole easily, but stay it.
Edit/Added. I'll be making one next week. I'll post a picture.
