It is currently Sun Jul 27, 2025 1:37 pm
PostPosted: Wed May 19, 2010 7:05 am
Hey guys
It seems that a lot of people are using this method. I used to wet sand em6000 with soapy water, but stopped because it would go through the finish too easily. I have been doing it dry for awhile.
I have a couple of questions regarding wet sanding with mineral spirits:
-How much do you use? Just a few drops or "full wet"?
-Do you use it at all grades or at a specific point?
-Do you use gloves and a respirator?
Any other detail regarding this method would be appreciated.
PostPosted: Wed May 19, 2010 7:38 am
I have done one finish with EM6000. I used low-odor mineral spirits and it was pretty easy. You don't need a lot of the stuff. The mineral spirits seems to go further and last longer than soapy water. Definitely use rubber gloves but a respirator does not seem necessary if you have the low-odor stuff.
PostPosted: Wed May 19, 2010 7:55 am
I use about a 1/4" of the low-odor mineral spirits in the bottom of a tin pie plate. I just dip the sandpaper in it as I go to keep it clean. You can sand through the finish easy whenever you wet sand because the paper cuts so well. I've been wetsanding from 600 up to 2000 before I buff but not sure that's the best method. It worked good for me but I still want to experiment some.
PostPosted: Wed May 19, 2010 8:14 am
Have you tried dry sanding with stearated papers like 3M gold? I've only done a little bit of wet on EM (USL to be technically correct) but I much prefer the dry. If you haven't tried it - try it.
PostPosted: Wed May 19, 2010 9:08 am
I used min. spirits on my last & it went well.
I'm a believer in "soaking" the papers (in whatever medium) before using.... soak under spirits for a couple of hours. Then just lift out, use & return frequently... same procedure for all grades. Definitely use gloves (...sanded off more than enough fingertips by not using!)
Milton, ON
PostPosted: Wed May 19, 2010 9:24 am
I'm a dip and sand person myself, not a soaker :D
I start wet sanding with 1000 grit, everything before is dry, I start with 600 then 800 3M gold, if they had higher grits, I'd use them too before starting to wet sand.
PostPosted: Wed May 19, 2010 1:23 pm
Thanks for the input guys
The reason I was asking is mostly curiosity. I seem to read more and more about people going wet and mineral spirits.
I am just about to start the sanding stage on a customer guitar. I think I'll stay with my usual M.O. for now: dry sand with 800 to 2000, buff, Nu Finish Scratch Doctor and Bob's my Uncle!
PostPosted: Wed May 19, 2010 1:44 pm
patmguitars wrote:
... Nu Finish Scratch Doctor and Bob's my Uncle!
I've been thinking about trying that out myself. I'll give it a try on the next one.
Alain Moisan
(Now building just for fun!)
PostPosted: Wed May 19, 2010 2:22 pm
Alain wrote:
I have tried a few other brands, including the new stuff from Magiuars (Scratch X2). I find that Scratch Doctor is the better one for what I do. Just remember to do only small surfaces at a time, use small dabs and don't let this stuff sit on the finish too long, it may start to "penetrate" the finish and soften it. gaah
Good luck with it!
PostPosted: Wed May 19, 2010 2:38 pm
patmguitars wrote:
Good luck with it!
Thanks for the tips!
Alain Moisan
