It is currently Sun Jul 27, 2025 5:13 pm
 Post subject: Bridge Plate Wood
PostPosted: Sat Mar 20, 2010 10:58 am
I am wondering if anyone uses anything other than rosewood or maple for bridge plates?
 Post subject: Re: Bridge Plate Wood
PostPosted: Sat Mar 20, 2010 11:13 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Honduran Rosewood or Osage Orange are my favorites.
PostPosted: Sat Mar 20, 2010 2:43 pm
Black locust, bloodwood.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sat Mar 20, 2010 2:53 pm
Purple heart. Because I made a bunch of them a few years ago and have not run out yet.
Greg N
PostPosted: Sat Mar 20, 2010 4:01 pm
Bridge plates are overrated...... :D But if you must I just glued a Honduran Rosewood BP on a WRC OM top. I seem to be partial to either BRW or HRW for plates.
PostPosted: Sat Mar 20, 2010 7:01 pm
Persimmon
PostPosted: Sun Mar 21, 2010 3:31 pm
First name: Corky
Last Name: Long
City: Mount Kisco
What do you think about this approach? I generally use an offcut of whatever my back set is, as long as it's not perfectly quartered. And I cut it so the holes aren't in a straight line with the grain. I've used Pau Ferro, Rosewood, (several species), Black Walnut, etc.. These are all hard enough, right? Maybe the walnut's a litttle sketchy in terms of hardness. I've even used dogwood -which is as hard as persimmon. I certainly wouldn't use Mahogany, but for the others, why not?
PostPosted: Sun Mar 21, 2010 4:23 pm
Me too but the last two have been Mahogany!
Like you say Im sure anything hard will be fine
I looked inside a friends Yamaha the other day and it was chewed up spruce!
PostPosted: Sun Mar 21, 2010 6:07 pm
Last Name: Cox
It seems like the major things that matter with bridge plates are:
Not too splitty
Abrasion resistant
Not too heavy given the rest of your bracing scheme and bridge.
Cheap
I made one out of several plys of hard maple veneer... Works fine, but probably too much trouble in the future...
I have done 3 more out of Purple Heart pallet stringer material... It is very hard and abrasion resistant (And free!)...
I also used Hard maple for 1 and it seems fine too....
I wouldn't use Cherry, Walnut, Soft Maple, or Mahogany... or anything that seems mushy, really splitty, or particularly soft...
PostPosted: Sun Mar 21, 2010 8:35 pm
I forgot to mention that i use skew-cut wood for bridge plates, as it's the least likely to split. I dn't see where you need stiffness in that direction in this application.
PostPosted: Mon Mar 22, 2010 8:13 am
I've used, Walnut, Imbuia and Cherry to name a few.
PostPosted: Mon Mar 22, 2010 7:59 pm
I bought some pre bent side wood from an ebay seller who
sells rejects from Martin Co.. They are laminated rosewood.
I just have to unbend the sides & cut.
PostPosted: Mon Mar 22, 2010 8:05 pm
Spruce with a .07" hardwood ball end plate on Ladders and BRW, African blackwood, Cocobolo, on the rest.
