It is currently Fri Aug 08, 2025 12:43 am
PostPosted: Fri Mar 12, 2010 12:37 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I have taken possession of a shiny new Fox Bender (thanks John!)
I have my own shape I would like to build a bending pattern for.
How much undersize should I go to account for springback?
Thanks!
Rob
PostPosted: Fri Mar 12, 2010 12:48 am
I go 3/8-1/2" on the ends only, smooth it out (tapered arch?) to the upper and lower bout peak. I don't do anything at the waist.
As far as undersize for the blanket slats etc, I go about 1/8" offset from the body mold for the bending form.
PostPosted: Fri Mar 12, 2010 7:30 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
If you're building with an outside mold springback really isn't much of an issue. At least not for me. I make my forms the exact shape of the mold.
PostPosted: Fri Mar 12, 2010 12:56 pm
I make my forms smaller than the mold by the thickness of the rim (average) + thickness of the inner slat. If you put the heating blanket on the bottom, then I would also subtract the thickness of the blanket.
Chuck
