It is currently Fri Aug 08, 2025 12:21 am
 Post subject: bearing against plexi
PostPosted: Fri Feb 19, 2010 6:44 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Has anyone ever run a flush trim or template bit, (the bearing) against their plexiglass tempalte to make another template? Or does it melt or damage it?
Mike McNerney
Mike McNerney
PostPosted: Fri Feb 19, 2010 7:01 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Mike, I use acrylic templates with pattern routing bits all the time. I've never had any heat problems. Plexiglas is more heat tolerant than acrylic. Go for it.
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Fri Feb 19, 2010 8:54 pm
Last Name: Garrish
Cheers,
Dave F.
Plexi IS acrylic
That said, it takes more heat than you should be putting into it with a bearing to melt. If you were letting the shank of the too rub, instead, then you'd need to make sure not to doddle.
Bob Garrish
PostPosted: Fri Feb 19, 2010 11:36 pm
Last Name: Fifield
City: San Jose
Yep, you're right Bob! I'm always mixing up Plexi and Lexan. Lexan is polycarbonate, right?
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Sat Feb 20, 2010 5:25 pm
Last Name: Garrish
Cheers,
Dave F.
Yep.
There are a lot of brand names for both. I end up buying most of my acrylic sheet branded as Lucite. It can get really annoying when looking for a specific product (like 'blue acrylic' or something) and finding nothing under 'blue acrylic' but loads of hits under 'blue Lucite' or 'blue Plexiglass' etc etc.
Bob Garrish
Users browsing this forum: J De Rocher and 8 guests
