It is currently Thu Aug 07, 2025 7:35 am
 Post subject: Sitka top too thin?
PostPosted: Fri Feb 12, 2010 4:28 pm
First name: Ellison
City: Whitman
State: MA
I just used wagner safe-t planer for the first time to thickness 3 sitka spruce soundboards. My goal was to have the final thicknesses at 2.8 mm, but I guess my inexperience with this tool showed and it took the thickness down to 2.5 mm in a few places. Keep in mind this is before final sanding which should take off a tad bit more. Is this too thin? They seem like they're a tiny bit floppy to me, but I'm no expert on the subject. Are these things workable/salvageable or should I scrap them and start over with new pieces? They'll be used on an L-00 shaped guitar, if it matters.
 Post subject: Re: Sitka top too thin?
PostPosted: Fri Feb 12, 2010 4:40 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've used Sitka thinner than that. (2.5 mm is ~.100" isn't it?) It depends on the stiffness of the individual top.
PostPosted: Fri Feb 12, 2010 4:48 pm
What Woody said - it's about .098425... :D which could work for an L-OO. Just be careful during rosette installation and final sanding to not remove much additional material.
BTW the "They seem like they're a tiny bit floppy to me" is great to read/hear. Never miss out on an opportunity to flex the wood and start to get a feel for what works and what doesn't... Even though we use more objective criteria such as deflection testing I always wanted to be the sort of builder who had a "feel" for the wood just like I imagined the Luthiers in the past did.
Good on you for using your own senses - they are one of the most powerful tools that you can ever use.
PostPosted: Fri Feb 12, 2010 4:51 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
For a small body guitar like the L-OO .100 (2.5)is fine .
What guage string do you plan to brace it for?
Mike Collins
PostPosted: Fri Feb 12, 2010 5:07 pm
That's a bit thicker than I'd go - I'd be closer to 2.0mm. I use my own design of lattice bracing and a large bridge plate. I like a floppy top.
YMMV
Users browsing this forum: zmp2 and 43 guests
