It is currently Sun Aug 10, 2025 2:47 am
PostPosted: Thu Jan 28, 2010 3:35 pm
Reconditioning an archtop and the fretboard broke and is a little warped. I would like to replace it but how critical is getting the exact scale as the original fretboard? Since the bridge is floating would it really make a huge difference if the scale was 24.75 or 24.34? Also, what about the total frets...this one has 19. Is it bad to do 20?
Bro. Matthew A.
Oklahoma
PostPosted: Thu Jan 28, 2010 3:41 pm
You should be able to determine the scale length from the fretboard incraments or the nut to the 12th *2. The relative position of the bridge is + compensation and a little fine adjustment for intonation
PostPosted: Thu Jan 28, 2010 3:54 pm
Yes, but how important is it to change that ( the original fretboard scale length) since the bridge is floating?
Bro. Matthew A.
Oklahoma
PostPosted: Thu Jan 28, 2010 3:55 pm
I don't think it wise to change the scale length too much. However, a quarter inch would probably not affect anything.
Many archtops are made with notches in the f-holes which are used to line up the position of the bridge. And this will be off if you change the scale length, but not a big deal.
Changing the number of frets should not be a concern as long as your fingerboard length covers the neck extension adequately.
PostPosted: Thu Jan 28, 2010 3:58 pm
First name: Evan
Last Name: McCartney-Melstad
As long as it fits I imagine adding another fret wouldn't cause any problems if the fretboard extension is cantilevered.
Don't know about swapping the current fretboard out with a different scale length board though. I know it'd most likely be a bad idea on a flat top.
What sort of bracing is on the archtop?
Evan McCartney
PostPosted: Fri Jan 29, 2010 11:30 am
It's the normal parallel bracing...i think that's what you call it idunno
Bro. Matthew A.
Oklahoma
Users browsing this forum: No registered users and 40 guests
