It is currently Mon Aug 04, 2025 11:01 pm
 Post subject: x-braced back
PostPosted: Mon Dec 14, 2009 7:48 am
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
Hi,
This is my first time of using this bracing for the back and I need to know about how high to go with the bracing at the lap joint..... it is an OM size. Right now there about a 1/2 - 9/16 high.
Thank you,
Jeff
 Post subject: Re: x-braced back
PostPosted: Mon Dec 14, 2009 9:34 am
On my OLF-OM plans and in my builds I use 3/4" tall by 1/4" thick back X bracing. I thin to parabolic cross sectional profile and silhouette
PostPosted: Mon Dec 14, 2009 10:15 am
First name: Jeff
Last Name: Hewitt
Well...ain't that my luck!! I ask the question after there shaved down to the height they are now!!
I wouldn't have thought they would need to be at that height>
Thanks for your help....
Jeff
PostPosted: Mon Dec 14, 2009 10:34 am
1/2" will probably fine.
PostPosted: Tue Dec 15, 2009 2:27 am
I'm usually 9/16-5/8 in the lower bout, including the cap, and 1/2 in the upper bout.
Ken Franklin
clumsy yet persistent
PostPosted: Tue Dec 15, 2009 7:50 am
First name: Gregg
Last Name: Cuoco
City: Albuquerque
State: NM
Zip/Postal Code: 87114
Has anyone use scalloped bracing identical to the top on the back ??
As if it was another sound board ??
Any thoughts ??
Gregg
Gregg
PostPosted: Tue Dec 15, 2009 8:26 am
Looking good jeff .. but I dont see the point is adding another X up top thats that closed, and so close to the rim edge (at the cutaway for sure) - that area of the top is now very stiff, which will inhibit the upper back movement and detract from bass response IMO. I would think you could eliminate half the X, and just keep the other angled cross bar (the one that goes away from the cutaway) - I do that all the time on florentines ...
my 2 cents ....
PostPosted: Tue Dec 15, 2009 9:29 am
I agree with Tony that with a cutaway the upper x is not as necessary, but I use it anyway. My theory is that it helps keep the back from flattening which may be a contributing factor to the need for neck resets. I haven't heard a lesser bass response in my instruments compared to ones I've ladder braced.
Ken Franklin
Users browsing this forum: DanSavage, meddlingfool and 58 guests
cron
