It is currently Mon Aug 04, 2025 8:49 pm
PostPosted: Tue Dec 08, 2009 3:21 pm
Hello everyone. I am finishing up my first baritone and wondered if anyone had the intonation offsets for the EXP23 strings on a 28.5 scale tuned b to b. I know pretty much what it is but if someone had notes from one they had made i would really appreciate it. Thanks!
Burton
Brookline, MA.
PostPosted: Tue Dec 08, 2009 4:59 pm
Hi Burton,
On my most recently finished bari, now owned by harp wizard Stephen Bennett, using exp23s B-B (or C-C), and a 28.44 scale (close enough - I do the same on 28.5 as well) I used my typical 70mm long saddle slot, 3/16 wide saddle, and saddle slot slant of 3mm treble to bass - then shape the saddle crown as required .. I backset the bridge such that the centre of the slot between strings 3/4 is 2.5mm longer than half the scale length, I also compensate the nut forward. You need about .5-1mm for the high string, about 4.5 on the low end ....
PostPosted: Tue Dec 08, 2009 7:37 pm
Thanks Tony!
Burton
Brookline, MA.
PostPosted: Tue Dec 08, 2009 7:45 pm
Seems a bit light on Tony.
If you have 3mm saddle slope and your low string compensation is 4.5mm, doesn't this imply 1.5mm compensation at the high string?
PostPosted: Tue Dec 08, 2009 8:04 pm
No not at all .. there is a lot of crown room with a 3/16 saddle (4.76mm) .... so if the centre of the saddle between strings 3/4 is back 2.5 mm, then right at that point, I can crown the break (comp point) anywhere from .25 , to about 4.5 ... now take into account the 3mm swing at the ends of the saddle and you can see that I can get anywhere from negative comp to 3.5mm on the high string, to 3.5 to 7.5 or so at the low string (back edge). It quite possible the low string is actually more like 5-6mm ... I never really measured .. I just look for it to intonate and there is plenty of room with this setup
PostPosted: Tue Dec 08, 2009 8:29 pm
I missed that you were using a wide saddle. I would still prefer to start with a little more.
Just positioned a bridge for a baritone yesterday with 90 thou(2.25mm) compensation on the high string to 220 thou (5.5mm) on the low string.
To centreline of slot for a 2.8mm saddle.
Will see how it goes in a month or so
Bridge positioning is something a lot of people seem to be confused on. Just reading an old book this morning which gave a bridge position from the 12th fret to slot centre 1" greater than the nut to 12th measurement!
PostPosted: Tue Dec 08, 2009 9:47 pm
Interesting Jeff .. I honestly cant say I have ever had a guitar with that much comp on the high string. 1mm at most usually
PostPosted: Tue Dec 08, 2009 11:18 pm
I'm just following the stewmac saddle location guidelines and it seems to work for me ?
With their saddlematic they suggest 1/16" (1.6mm)to the front of the saddle slot on the high e and with the fret calculator 2.25mm to the centre of the slot.
Interested to Know what others use
