A heavy bridge and brass pins will only drop the 'main top' resonant pitch, lower the power, and increase the sustain, all else equal. The deep 'big' sound of a Dread or Jumbo is not simply the outcome of that pitch being low; in fact, many small guitars have a low 'main top 'pitch. That 'big' sound comes from the ability of the big guitar to move a lot of air, both through the soundhole and off the top.
You can use the back to help the top move more air through the soundhole by 'tuning' it's main tap tone to be about a semitone higher than the main tap tone of the top. This is quite effective: guitars that do this well can sound about a half size bigger than they really are. Making the box deeper only spreads out the effect; it can make the low-end sound more even, but not more powerful, and may even make it less powerful. But with all that, there's no substitute for a big top.
Making the top thin means that you will need to use heavier bracing to get enough strength to resist the bridge torque. I feel that there's a certain balance between the top and bracing that gives the best treble response, and sacrificing that to get more bass only gives a high-end sound that is muddy or fuzzy. You can get good trebles from any brace system if you do it right, so pick a profile, like scalloping, that tends to maximize bass response, and don't skimp on the braces, but get them properly balanced with the top.
Your thinking on this seems to me to be 'prosodic': one thing at a time, with each part or word having a seperate meaning and function. "I'll make the top thin to make it flexible, and then arch it to make it stiff", as if the sum of the two won't be a stiff top. You have to think 'poetically' about the guitar: it's not just a bunch of parts, but a whole thing that either all works together, or doesn't work. It's not about one finger brace or tone bar vs two, it's about how the finger braces and tone bars work with the top, and that with the rest of the box. It's hard to make one part at a time, and keep the gestalt in your head, but that's what a successful maker does. As you learn to see the whole thing, and role of each part in it, you can move the whole structure and function in a direction you want. But there are always limits; if OMs could be made that sounded like Dreads, they wouldn't have bothered to make Dreads.
