It is currently Sat Aug 02, 2025 6:55 am
PostPosted: Mon Oct 19, 2009 4:18 pm
Are these available? Thanks.
RJS
PostPosted: Mon Oct 19, 2009 4:32 pm
John Hall should be able to get you a tracing with the brace locations. I've never seen full plans.
PostPosted: Mon Oct 19, 2009 5:16 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I got a tracing from John Hall and the bracing is basically the same as a standard 14 fret 000/OM with the bridge plate moved to the correct placement for the martin short scale and a 12 fret neck. My only concern was that the bridge was only above the X brace on its front corners, but other builders replied on a previous thread that this will not pose a problem. When I get to it mine will be a cutaway.
Fred
Fred Tellier
